can someone help me with my saf cossie brakes!!
G911 TTA
ive put 4x4 cosworth calipers on my 2wd saff and i got some cosworth discs off a mate.i put the disc on and then went to put caliper on and i cant bolt caliper on properly because its as if the disc is on the hub 2 far!! its as if the disc needs 2 b spaced out away from the hub.could it be that they are the wrong discs???.possibly they are 2wd discs so dont go with 4x4 calipers????? i havent got a clue if 2wd discs and 4x4 discs are different.so maybe this is the problem! can anyone help me please???the discs are 283mm.
Resident Wrestling Legend
for the 4wd car, you need 4wd discs
they won't be interchangeable
and why are you putting single pot calipers and smaller discs on the 2wd car?
G911 TTA
i bort the car minus quite a few bits.needed brakes and got these cheap thats why ive used them.its the front brakes im talking about.im confused....................
alrite ro.broke the s2. ang got a cossie cheap
The Enigma
12-09-2015 10:12 PM
