24ltr Vs 50ltr compressor
seen a compressor im thinking of getting, both are 2.5hp and have 9.5 cfm.
difference is the 24ltr one is about 80 quid and the 50ltr is double that. both are made by wolf
what would be the advantage to having teh 50 one?
looking for it to run a few air tools and have a play with spraying.
just a bit of fun and learning for the spraying really, as long as it puts some paint on the panels half decently im happy.
50 litre stores twice as much air so if you use more air that the compressor can make it won't run out as quick. you really need bigger for spraying.
if said tool did not use more ait that the compressor makes, you couls run it all day long, it uses more you will need breaks for it to refil.
25 Litre, will be fine for spraying panels, as you should not apply too much in one go anyway, most guns are HVLP anyway.
Air tools are seriously hungry, way more air hungry than the average spray gun.
9.5 CFM, doesn't actually mean a lot, FAD is a better measurement of performance, that is FREE AIR DELIVERY.
I have the 25 Litre Wolf in my garage, and a SIP 25 Litre in my dads, the Wolf is MUCH better, very quiet(for a direct drive compressor) way less noisy than the SIP.
If using air tools a lot I would defo go for a 50 Litre.
