Can a t34 just s...t itself?
#41
30psi, on greens is running extremely close. injecter limits.
hope ur feul pump doesent suffer a slight hicup. also 30psi on greens,, ur misfire will be coursed bye the spark been blown out probly, take the boost down to peak at 26psi, seen how ur misfire is then. all im gonna say is, i had the same prob spiking at 28psi. Thats witl all the leads,gaps on plugs set good, all uprated leads, group A coil. all new roter cap and arm. But really it needed a coil pack from stu. Spiked at 26 psi on greens 332bhp 368l/bs. The feul line on 28psi was just on the lean side tooo!!!! i can show u the graphs,
#42
Norris Motorsport
m nettleship,
You really should'nt make comments about things you clearly no nothing about.
Running 30psi as a brief spike is no problem on greens. In fact theres just about enough fuel on std injectors to peak 30psi in the midrange.
I have a huge amount of experience mapping cossies so to suggest I may have left it running lean is rediculous!
T34's are a little hit and miss for failures. Some go on for years peaking at 30 psi whilst others can fail fairly quickly. The biggest killer of T34's is trying to get the turbo to hold over 25 psi at high rpm, as this always kills a T34 VERY quickly.
#43
never said it was running lean Karl, Just said it must be running very close. Like my sapph did wen run in the gunship conversion on yellows, then on greens spiked at 1.7 bar. at about 3400rpm.
The feul line on the graph was just a bit on the lean side. ill show u the graphs if u want.
also i think the misfire prob wud prob go away if turned down a little too.
#44
It was boosting/running fine without no problems for like 3-4 months after the remap only started miss-firing/arsing around as soon as it went onto Nobles Rollers. But as soon as i get the turbo sorted ill just take it back to Karl to sort it out.
Ill keep you all updated and on the outcome of the turbo....
#46
14000+ post superhero
#48
I got it from a Guy up in Scotland. He was breaking a cossy on ebay at the time so i got chatting to him and he had one which he said he bought for like nearly Ł900 from Universal Turbo's iirc and only did around 1000miles on it. Said it was in storage for the last 4 years.
He sounded/was genuine enough and i told him ill be getting my cossy mapped by NMS as soon as the turbo goes on. He said yeh if theres anything wrong with it as soon as ive put it on he'll guarantee it which was fair enough for a 2nd hand turbo...
Like i mentioned before managed to do 2000miles on without a problem but now![Wall](https://passionford.com/forum/images/smilies/wall.gif)
#50
Norris Motorsport
Why is he asking for trouble with 30 psi on greens?
The issue with his turbo failure is nothing to do with the injectors. T34 turbos can fail when running 30psi, and this has nothing to do with the fact he is running greens.
#53
Norris Motorsport
LOL evening tony. Its a bit late to be up drinking tea is'nt it?
Actually just to add for those who may be reading, the car in question on this post simply peaks at near 30 psi before being mapped to tail to 22psi at higher rpms. (I don't want folk to think its ok to hold 30psi on greens as this is beyond the flow rate of greens at high rpm)
#54
*** Sierra RS Custard ***
Karl, have you just popped on to talk to the retards for a while to make you realise how good your life is when not on a forum talking to people who dont understand anything about injectors? ![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
Looks like hard work so far, but fair play to you for sticking with it, lol
#56
Ahhh fuck it, if uncle Tony can say Hi..
Hi Karl...
Must pop over sometime soon, end of uni season so I have exams to get out the way... I'll buzz you in a week or so.. if you could arrange a pass out with the tea lady... oh and I'll bring the Transformers DVD I promised..
Jake
Hi Karl...
Jake
#58
Norris Motorsport
Chip,
Yes it is rather like sticking pins in your eyes trying to educate folk on here. LOL
That said I'm actually on here to read the Nurburgring thread to see how everyone got on, as I hav'ent been into work since last week, so thought I'd catch up on the trip.
#59
Norris Motorsport
Hi Jake, yes thats fine mate give me a call soon.............
Tony..........apparently the problem for turbo failure is the green injector, so 4 or 8 you're still in trouble.............Think 8 X 1000cc injectors might be just about man enough for a 30psi peak on a T34?
#60
Karl if oil starvation aint the cause for the turbo's failure and it turns out just to be my bad luck/one of those things that it died, would you recommend i get a new unit or will a full recon one do it to the run the same spec/boost you mapped it at?
If so is it just a 360 bearing that i should be after in the upgrade like?
cheers
reiss
cheers
reiss
#61
Norris Motorsport
We only use turbo technics for our turbos, and allthough classed as a rebuilt turbo, they actually feature new turbine wheels and shafts, new exhaust housings, bearings, etc. The only parts re-used are items like the compressor housings which are rarely prone to problems.
Many so call re-cons used old turbine wheels that have been blasted to look new, and hence un-suprisingly fail quite early.
Hence I would advise you buy your replacement from turbo technics, or you can order one via ourselves at the same cost to you.
#63
RWD_cossie_wil: I was going to call you on Saturday then to pop over and check it out but went go-karting + the weather was too nice to be arsing around with it
#68
27psi. 30psi, is to mutch 4 greens, weather its lean or just ok, and lets face it, it will only be just ok, not enough feul to keep em cool enough.
more feul, cooler pistons, cooler pistons means cooler zorst gases. Ie cooler Turbo.
#71
Fuel cooling is vastly over-exaggerated...., you can run much more boost at 3500Rpm as you get twice as long for the injector to fuel than you do at 7000 Rpm, so in effect it only matters what injectors you run if you are running out of duty cycle at the top end.
#73
Norris Motorsport
m nettleship,
I usually run greens about lambda 0.84 in the midrange when peaking at around 28psi, richening to lambda 0.82 at high rpm, where the boost will also be mapped to tail back to around 22psi.
If you have a car mapped by myself that is running lambda 0.90 at 27psi then you have problems with your car/ecu/electronics/TPS/fuel system etc, and should have the fault investigated, as it will not have left me running that way.
#74
not the fact there not enough feul then?
Anyway Karl, all am saying is 30psi on greens is asking 4 trouble. and he got it. plus he running nearly standard ignition too.
anyways have a good day.
#76
are they all running standard ingnition?? stu?
I new wat reisskahn was running i seen it on the dyno, 4 his car 30psi is to mutch.
#77
Norris Motorsport
m nettleship,
I really am struggling to work out whether or not you are purposfully trying to be difficult or whether you are making your own incorrect assumptions..
Let me say once more and PLEASE LISTEN TO ME!
It is fine to run 30psi midrange on greens provided it is mapped correctly to do so. It is not boarder line in anyway. For example there is enough fuel available from greens midrange to run as rich as lambda 0.75 if you so desire. However all cars mapped by myself will leave me running around lamba 0.84 midrange. If you have seen a car mapped by myself do differently on a rolling road, then either the car is running with faults OR the rolling road equipment is giving incorrect readings.
#78
m nettleship,
