Can a t34 just s...t itself?
Old 06-05-2008, 10:41 PM
reisskahn
reisskahn's Avatar
Default Can a t34 just s...t itself?
Had my cossy remapped at NMS about 6 months ago only done like 2000 miles tops since then. Just prior to the map i fitted a t34.48 which supposedly done 1000miles had 360 bearing but was in storage for 4 years. Anyways while trying to fix a fricken miss-fire problem last week which i ended up changing the plugs Karl fitted (Denso IK27) to the 701's i decided to go for for a little blast.
Missfire was slighly cured but not fully and upon the test drive i knocked it back from 3rd to 2nd (as i was cruising at the time) and heard a loud whistle screaming type of noise which i knew soming was fooked.
Now theres all white smoke and a nasty rattle from the turbo. Upon removing the filter hose the shaft looks intact with no movement in it but hesitates to spin on idle and when reving the engine.
What i dont understand is whats happend to it and why??? i thought the turbo should have able to handle this kinda boost (was peaking 30psi, dropping to 26 and then holding 20 at top end)
I dont really want to replace it without knowing what the cause was.
Also who would you recommend if i want to get mine rebuilt?
Here a video if u can make some sense out of it?
http://s50.photobucket.com/albums/f3...t=SSL21983.flv
Old 06-05-2008, 10:45 PM
Lee_R21Turbo
Lee_R21Turbo's Avatar
The blades look like summat has gone through it to be honest mate!!
But that kind of movement definately isnt right. It might of lost a blade off the rear wheel. Take the downpipe off the back of it & have a peek.
Old 06-05-2008, 10:49 PM
15D
Italian convert
15D's Avatar
Bamber wrecked a 500 mile old T34 with exactly the same effect.
Deffo a case of the turbo has injested a nut, washer, clip or some debris
reisskahn
reisskahn's Avatar
Lee_R21Turbo: I reckon something defo has gone from the rear of the turbo as i could here it rattle in the exhaust. Initially i thought i must've dropped a valve so should count meself lucky if its just the turbo but i dont understand why i wasnt even ragging it
There was no dump-valve could that make a difference?
Old 06-05-2008, 11:39 PM
reisskahn
reisskahn's Avatar
Also can anyone recommend a good place where i can get it reconditioned?
Old 06-05-2008, 11:55 PM
stage 3 muppet
stage 3 muppet's Avatar
before you do anything pal i would check the turbo oil feed pipe isnt blocked!!!
take top oil feed pipe off the turbo ,remove coil lead so it doesnt start then place end of feed pipe into a clear small bottle and crank it over .
make sure it isnt blocked ..
Old 07-05-2008, 12:21 AM
reisskahn
reisskahn's Avatar
Thanks for the info will defo check that....
Old 07-05-2008, 01:44 AM
R5FORD
R5FORD's Avatar
sounds like oil starvation to me
Old 07-05-2008, 02:13 AM
reisskahn
reisskahn's Avatar
Thats what we initially thought but:
1.) Oil was checked prior to starting car from cold and was just at/above the max mark. Could being just above max make a difference?
2.) When the car was miss-firing/holding back is the oil circulation stopped/disturbed as this was the original problem which i was trying to rectify?
3.) There was no smoke on idle prior to this happening take it the oil seals in the tubo were ok or not nessescaraly?
Its now giving out white smoke from the exhaust and around the turbo/downpipe what is that indicating?
cheers
reiss
Old 07-05-2008, 02:48 AM
R5FORD
R5FORD's Avatar
mine shit itself du to oil starvation, had no signs of it being starved of oil, even checked the line etc but when the turbo was taken apart the conclusion was oil starvation, i has white smoke come out from my aifilter
Old 07-05-2008, 03:43 AM
The bearing/surfaces are shagged, no doubt due to foreign matter in the oil supply.
I would use the TURBOCENTRE 01924 404112, speak to Andy Or Craig, they will soon sort you out.
The damage is on the exhaust side of the bearing ring, so that is why you have white smoke not blue.
Old 07-05-2008, 06:44 AM
Turbocabbie
Top Cab !!
Turbocabbie's Avatar
i would use vince from cr turbo's myself
Old 07-05-2008, 08:46 AM
RWD_cossie_wil
RWD_cossie_wil's Avatar
Reiss give me a ring on friday mate, I will drop over If I get chance and have a look for you
Old 07-05-2008, 10:42 AM
reisskahn
reisskahn's Avatar
RWD_cossie_wil: Thats great really appreciate that. Will hopefully call you on Friday fricken cossies
Turbocabbie: Will hopefully call CR TURBO see whats the crack with getting mine reconditioned...
tabetha: Again will call TURBOCENTRE but how can a foreign matter enter the oil? Is there any chance anything could've entered the engine side of things?
Old 07-05-2008, 10:47 AM
costina
Live long and prosper!!
costina's Avatar
Me too and a good price
Paul
Old 07-05-2008, 10:49 AM
garrett-killer
garrett-killer's Avatar
i noticed the same thing on my t34,
it didnt spin on idle,
it made good boost,no noise and dont need oil or anything.
2month ago i rebuild and balanced it,
the bearings and the wasnt the best,but looks ok,
also the blades look good.
on the first start is looks very similar to your video.
is it normal that it stop to spin on idle?
best regards chris
Old 07-05-2008, 12:50 PM
Mike Rainbird
Caraholic
Mike Rainbird's Avatar
If you have a rattle in the exhaust, make sure a turbine blade hasn't let go, as this would cause the turbo to go out of balance and then lunch itself completely. This is a common thing to happen to a T34 running such high peak boost.
Old 07-05-2008, 01:01 PM
R4N SS
R4N SS's Avatar
t34s can fail - i used to change mine on almost every service
Old 07-05-2008, 01:12 PM
Tim
Tim's Avatar
After doing 3 in a row i would tend to agree
Old 07-05-2008, 01:38 PM
xr4x4rs
xr4x4rs's Avatar
mine failed last night
its only done 60 miles
was not impressed
i primed the turbo as normal, it runs a filter aswell
had fresh oil in it
took it out and it sounded like it was surging, so put it down to the tps messing with the amal valve, until i noticed i was on getting 10 psi
turned round to go home, heard a loud clinking noise as if the prop was hitting the exhaust then nothing, boost gauge read zero
im in the middle of taking it off as its being picked up tomorrow for inspection ,to say im very unhappy is an understatement
it isnt starved of oil as it has a brand new oil feed line aswell and is on 2wd set up so gets almost instant oil supply, return isnt block either, and no particles came from the air filter
so this should be interesting
but when i first fitted the turbo and we fired the car up there was a strange ratlle, it sounded like a aux belt tensioner going, so i put it down to that, as never in a million years id think it was a brand new turbo, guess i was wrong
but yes turbos can shit them selves instantly
Old 07-05-2008, 01:40 PM
reisskahn
reisskahn's Avatar
Mike R am hoefully whipping the turbo of anyway (only drove it off boost to get home its been parked up since)
Would you say thats a lot of boost for the turbo as Karl set it up for me and would've advised me if it was going to cause problems? Lot of he turbo companies are saying they only recommend me running 22psi on it
Ive picked up a replacement one but dont really want to fit it without finding the cause first or thinking about getting this one fully reconditioned with possibly a ball-bearing fitted into it
Old 07-05-2008, 01:43 PM
reisskahn
reisskahn's Avatar
xr4x4rs: Thats not good mate sorry to hear that.
Think ill finally have to accept the fact that cossies are Time Bombs just waiting to EXPLOD
Old 07-05-2008, 01:47 PM
Mike Rainbird
Caraholic
It would certainly need a 360° thrust bearing on it at that level?
xr4x4rs
xr4x4rs's Avatar
ime bombs aint the word mate
i almost turned mine into a bomb fire the way its be playing up with me lately
Old 07-05-2008, 01:51 PM
smokey
smokey's Avatar
My t34 digested a bit of my K&N filter!
Old 07-05-2008, 02:35 PM
cossie4i+
TT T38 Power
cossie4i+'s Avatar
was not impressed
had fresh oil in it
Not even more problems Rich
Steve.
COCHYN
COCHYN's Avatar
Old 07-05-2008, 02:43 PM
m_nettleship
m_nettleship's Avatar
midland turbos, did a good job 4 me, quick aswell.
im sorting thinking, oil starvation, and it chucked a blade. ie the rattle.
how many miles had the turbo done reiss, and didnt it have the misfire on the rollers at nobles couple months back?
Have u checked the turbo oil feed pipe, mine was a new braided one. peice of mind.
Do you run water cooled Turbo?
Was it 360 bearing?
sorry if u allready answered some of these questions. rushed reply.
Old 08-05-2008, 01:11 AM
reisskahn
reisskahn's Avatar
m_nettleship: Supposedly the turbo had a 360 bearing and had only covered 1000miles from new but was in storage for 4 years when i purchased it. Ive only done like 2000 miles on it tops no more and yes it was water-cooled.
I was trying to rectify the miss-fire from the Nobles Rolling Road Run. Funny thing is car drove up fine prior to it going onto the rollers and since then its just been a miss-fire headache and now the turbo
Will check oil feed line but is there anything else i can check?
Old 08-05-2008, 01:24 PM
m_nettleship
if it was me, i wud have prob sent the turbo away 4 rebuild 4 years is a long long time. Did you u pre oil the turbo b4 installing, or turn the engine over to get the oil there b4 u fire it up?? The seals may ahve gone hard dreid up etc etc.
unbolt the oil feed of the turbo, and then turn to engine over on the key, with alot of rag and clothes ready around the pipe, take a lead of to stop the car firing up though.
If i remeber the misfire was slight wasent it?? wat injectors u running, wat chip, wat plaugs, wat ht leads
Old 08-05-2008, 01:30 PM
reisskahn
reisskahn's Avatar
m_nettleship: The spec is:
Greens
Denso IK27
Motorsport 909 Leads
NMS LIVE MAP (chip)
Like i said its was mapped last October ran sweet until i had it put onto the rollers were the miss-fire started and never stopped since.
Pretty sure we would've pre-oiled the turbo but i had no problems during the last 2000 miles. Ill hopefully take the oil feed pipe off tommarrow and see what happens. Either way turbo needs to come off
Old 08-05-2008, 01:38 PM
m_nettleship
GREENS and i read 30psi. Thats not good.
you running a distributer or coil pack conversion, phase sensor might be nackerd in the bottom of the distributer. it will misfire under load. but will rev freely no problem.
qI wud take the water system of the turbo aswell. best think i ever did,
Old 08-05-2008, 07:11 PM
reisskahn
reisskahn's Avatar
Running the std dizzy had a new phase and crank sensor lined up but thought i'd try some 701 plugs which were working fine in another car. Was on the test drive when the turbo spilled its beans.
30 psi well thats a short/burst peak that its seeing but like mentioned before it was Mapped by KARL who clearly indicated that the way its been mapped its all safe and thats all i needed
Ill hopefully be whipping the turbo off pretty soon and take it from there...
Old 10-05-2008, 07:17 PM
m_nettleship
it must to lean,, i no karl and i think hes the best going, touching 30psi on greens is asking 4 alot of trouble.
Old 10-05-2008, 08:24 PM
fuzzy
14000+ post superhero
fuzzy's Avatar
i wouldnt bother reconditioning . they tend to not last very long and as a brand new T34 can be had for about Ł700 ive found recon is a false economy.
Old 10-05-2008, 11:12 PM
m_nettleship
How u work that 1 out?
Ł200 rebuilt turbo. prob get a new shaft and seals 4 that.
Old 10-05-2008, 11:54 PM
reisskahn
reisskahn's Avatar
what do you mean, if thats the case like am sure Karl wouldn't have mapped it like that Could that also have anything to do with the turbo going pop or not really?
Cant be arsed to whip the turbo off at the moment but likely going to get it fully reconditioned ill see how it goes
Old 11-05-2008, 12:17 AM
mechanic28
mechanic28's Avatar
Karl would not have mapped it lean the whole point of a live map is too get the most out of your engine safely!mine is set to 30psi,27 mid 23 at rev limiter mapped by karl!i would say your turbo has just died due to the fact its been sitting around for so long!
Old 11-05-2008, 12:27 AM
reisskahn
reisskahn's Avatar
Fair play and no disrespect to Karl he does know his stuff i just told him do whatever you gotta do to make it fast and reliable as it can be and thats how he mapped it.
If the turbo sitting around was an issue surely we would've noticed problems/smoke straight away like. I mean its done 2000 miles unless the guy blagged it to me and it aint what he said it is. Oh well could've been worse
Old 11-05-2008, 12:37 AM
mechanic28
mechanic28's Avatar
indeed fella!sods law!
Quick Reply: Can a t34 just s...t itself?
