vernier wheels
vernier wheels
when you buy a cam kit does the vernier wheel that you use have to be from the same manufacturer as the cam,or could you use a piper vernier wheel with a kent cam or vice versa
PassionFORD Member
yeah you can mix and match mate. as long as they are designed for the same engine no reason why they cant work together. a lot of people run cams by manufacturer 'A' and verniers by manufacturer 'B'
ok cheers mate,i did think it would be possible as you can use standard ford cam wheels on all cams so the verniers would all fit btu just wanted to make sure,cheers
Adam Graham
06-09-2015 06:04 AM
