T4 engine bore size
03-05-2008, 08:20 PM
Passion for Fords!
T4 engine bore size
guys, my 200 block is bored to .5 already, and needs another bore, which would take it to .75
does anyone run a 500bhp T4 engine at .75? or do i need to carry on with my plan to thin wall liner the block?
03-05-2008, 08:25 PM
didn't think they did .75 o/s pistons? Thought it was 0.5 and 1mm o/s? Can't see the problem running 1mm o/s pistons, I know of people who have run 93mm WRC pistons which is quite a lot over +1mm pistons.
Is your block long-studded? As that would be my major concern with a T4 engine.
03-05-2008, 08:28 PM
Passion for Fords!
think they do a .75..?
its going for long studding,
i was under the impression the bore would get to thin going near 1mm oversize
03-05-2008, 09:12 PM
what thickness are the bore walls just now?
the one that cracked on m engine was only 3.5 mm thick so you want to try and be over 4mm.
03-05-2008, 09:13 PM
Passion for Fords!
not sure euan,
what was yours bored too?
03-05-2008, 09:15 PM
my block is 0.25 over standard.
03-05-2008, 09:18 PM
Passion for Fords!
03-05-2008, 09:21 PM
yeah it cracked the bore with the thinnest wall thickness.
Its one of the 99 blocks not that I really thick it makes any odds.
measure the wall thickness as blocks do vary and yours might be thicker.
03-05-2008, 09:22 PM
Passion for Fords!
mines a old type block, fitted to the car when new.....
where did you measure the wall?
03-05-2008, 09:23 PM
Quote:
Originally Posted by
JTECHSAFF
try to get down the water jackets surrounding the bores.
03-05-2008, 09:25 PM
Passion for Fords!
thanks euan, il have a look see what ive got, otherwise i will get all four bores thin walled back to std size
03-05-2008, 09:27 PM
It might be ok as I had other probs on the engine that "might" have contributed to the cracking.
03-05-2008, 10:02 PM
Passion for Fords!
04-05-2008, 09:10 AM
Passion for Fords!
s1cab
26-07-2018 06:11 PM
KW-rscos
11
31-08-2015 01:51 PM
lee2cossies
26-08-2015 10:04 PM
marky_g
03-08-2015 04:45 PM
