cossie gurus help...please
i baught a 350bhp saph yesterday & came off a roundabout sideways & mounted the curb, it minced the egsaust & broke a mount by pushing the engine up about 4 inches i started it strait after to reverse it off of the curb & it cut out after 10 seconds then i towed it away & left it over night in a garage, so today i changed the mount & egsaust no problem, pushed the white safety switch in in the boot & went to start it but no fuel pump & no spark so i checked to see if there was power going to the pump & there was none but the pump works fine after a wee test but still no startin it turns over fine aswell.........any ideas folks.....please
immobiliser yes
but dpends on who wired it, could do starter,coil or fuke pump aor al 3 or just 2 lol
but if your not getting fuel pump or spark then im sure if the ecu hasnt picked up a crank sensor signal then they wont work well spark wise anyhow
fuel pump could be split wires when the exhauts come off etc
aka Turbosailorboy
The engine cranking, ie starter motor solenoid supply is totally independent of the ECU. It is from the car loom
So the engine will turn over without the ECU even being in the car
When you put the ignition on does the fuel pump prime for a few seconds or does it stay on ?
the egsaust was pushed under the car which then pushed the engine up out of the rubber mount,
i have gave the wiring a check & it all looks fine but why both no fuel or spark?
i have a mates cossie thats been getting robbed for bits so i'll try the crank sensor tomorow but if anybody has any other ideas??
right after checking the crank sensor, all the wiring under the bonnet & underneath about 4 times, removing the ecu & refitting it, checking all the fuses & relays under the bonnet theres still no spark or fuel pump,. so im away to put it back to the garage that fitted the imobiliser & alarm ( about 3 miles away)
unless theres anything else you know of before i start spending???
sorry to hear tis fella!in hinsight might of been worth getting used to 350bhp cossie first rather then giving it large straight away! u say the engine was forced up!thats takes some force to do that!!have a look around make sure no wires are trapped, broke or been pulled out of any of the plugs in the engine bay!
shit luck mate will needs pics
have a good look at all the wiring earths etc also on the engine wiring loom check that you have 12v feeds to both of the fuses also try your ecu in another car?
my ecu has an ahmed bayjoo stg 3 chip so i doubt it would work in my mates standard cossie even though its been getting robbed for the last 2 days
dont matter what chip it has in it does it make the fuel pump prime is all your looking for are you getting power to both the yellow relays on the engine bay wiring loom?
sorted now as there was a blown fuse hidden behind the dash for the immobiliser or something, she lives on anyway
i'll get some pictures up tonight
Russ Payne
25-09-2015 08:29 PM
