How much boost can i run through a 205 block +1mm rebore?
#41
Originally Posted by Ian2wdsaffcos
Pete,
How many times has the engine been rebuilt mate as normally people go to 0.25mm oversize, then 0.5mm...............
where's mr norris when you need him
#44
#45
Originally Posted by peteh
bttt so stage 3 would be safe then?
#46
#48
I was running 92mm accralite pistons in my 205 block at about 400bhp and it did about 5000 miles before it cracked number 2 bore (about 3inchs) and started to misfire but it did not explode . I'm running a 202 trany block at the moment see how long that lasts!!!!
#49
ian m,
i know lots of people on 205 blocks running high boost with no issues i think markk is actually a bit more than + 1mm and he runs approx 30 psi
absolutely ive seen more 200 blocks cracked than 205 although thats usually down to poor preparation of the block before assembly.
totally agree there !!
what alot of people fail to remember is how old is your 205 block ?
and not only the age but what is it like internally as blocks corrode from the inside out especially when used without an anticorrosion device !
i prefer to use the 205 blocks for a few reasons of my choice , but they have to be carefully selected !!
#50
Originally Posted by markk
ian m,
#52
my 1st 205 was cracked but im certain at was cracked b4 it was rebuilt and no one noticed it
the 2nd one i had was fine , i used to run 38 psi peak and hold 32 iirc with no problems at all
luck of the draw me thinks , you win some you lose some ,
#54
peteh,
so not much use to me then as i wasn't there when they rebuild it , it was the old block that they rebored +1mm if that helps.
this is why a new block will be specified for all high power customer rebuilds , as was said above its a reliability thing. alot of my work is done for me in the name of research and development , but would i always sell it to a customer , no is the answer, unless the risks are accepted by the paying customer, to me you are going to have to take that risk that whoever built that engine knew what they were doing and hope its ok
#55
its funny phil mentioned using liners , as thats what the engineering company who got my replacement block ready use put in mine .
i allways thought they were a bad idea till i posted about it on here and found out they can be a good thing if done properly
#57
as markk says if it has allways had plenty of anti freeze in it should be ok internally you could allways take your water pump off and have a look that will give you a good idea.
#63
I spoke to one of rouse's old engine men when i built mine and when i asked how much power a 205 block could take he told me because of the way cast has to settle he would prefer using an old crack tested 205 block in favour of an unsettled 200 block
he said when they were 1st racing they used to bin the new 205 cossie block and used to hunt breakers yards down to find any old 205 blocks that had had done at least 50k as they had had plenty of heat cycles and had settled , he said they even favoured them over the 500 blocks until they had done milage on them!
I currently use a 205 block and hold 30psi and its as happy as a pig in shite
Pugo
PS they were all on std bore though
Pugo
#65
Pugo
Pugo
big_Rad
15-09-2017 09:36 AM
James Porter
28-10-2015 12:17 PM
cossiedean84
37
02-09-2015 10:19 PM
