A quick big bhp Transit question
Can't believe i just asked that
Does anyone know what diff ratio a short wheel base 2.0l petrol Transit would normally run?
Also are there any aftermarket wheels that will fit it say off a people carrier or something???
And tyres can i put proper tyres on it or does it have to have van tyres if it isn't being used for carrying stuff????
Originally Posted by kaliber cossie
got a set of compomotive 5 studs on me ford connect van same design as focus rs will post some pics tomoro
UNAUTHORISED DEVELOPMENTS
I don't know the diff ratio but i know someone who has a 2.0 transit that is now running a v6,and apparently the diff from a minibus is better for motorway cruising. 16" five spoke alloys are available from a place near liverpool,these are heavy duty van wheels,and fit on the standard hubs. If your not carrying weight however,see the cathburn customs transit in performance ford,this has a four stud conversion on it using fiesta discs,and rs turbo drums. White indicators are also available. I own an r reg 2.0 dohc transit running on lpg,and find the engine to be the most unsuitable engine for the application,and would love to put a nice torquey v6/8 in there but can't have the vehicle off the road due to work. Anyway do you have a project in mind?
the old transits have a massive stud spacing on them unfortunatly so your limited to what will fit there are a few available but they aint much cop , cant you just change the hubs , although i reckon you might have trouble on the rears as i think they'r a non removable part of the halfshafts
wont cossie rear set up fit with a bit of extending here and there
Cheers for the info mate
The project i have in mind is this beastie i bought today!
Although i don't want to go ott on it as i like it sleeper appearance but would like to change the rubber to something a bit more suitable and am just curious about the diff ratio as at 80mph it is revving to 4k
The mirrors seemed fine to me mate but then i don't plan on using it every day its just a toy! Do you know what size the wheels/tyres will be on it now? I know they are from a late Transit.
Originally Posted by DazC
Originally Posted by b19bal
granada alloys ????
so transits had 4 studs too
thats what i ment, sorry, granada alloys or some tranists had 4 studs im sure hence the p100 4 sud conversion
The P100 might have used the same axle but with 4 studs which is where the 4 stud conversion for the rear comes from but I have no idea about the front....
Welcome to the club mate
Diff ratio is on a tag secured by one of the diff mounting bolts.
Will be either 4.54:1 or 5.1:1
Are you on four or five speed box?
Its a T5 from what i can see
Knowing tyre size and 5th gear ratio, we can calculate what diff ratio you have, assuming that your speedo is correct
Looks like you're on a 5.1:1
Incidentally, have you got the small metal water pipe that goes from turbo to thermostat housing, mine's cracked? (2wd)
