pectel monitor people
just got my monitor fitted with a new plug and pc data download plug by ryan (car looms uk) cheers mate
all seems to be working fine apart from when you go to page 8 for download data logging it says
DATA CORRUPT - MEMORY BATTERY FLAT
so how do i rectify this? where is the battery as i dont see 1 or is it under that board? i didnt want to pull it apart too much for fear of fcuking it up lol
it is version 6.50e................ memory 128k
an internal pic
also i have full throttle angle 85 degrees but 2 degress when completely off throttle? is this correct as i thought it would be 0 degrees
And lastly what pc software etc do i neeed to actually download and view the data logged recordings
thanks
marc
an internal pic
thanks
marc
Monte Geek
Is it not just a capacitor that holds the memory power for a short while?
Have you had it on power for long?
Have tried recording new data?
If you undo the four hexs in the corners the pcb will come out, maybe there is a battery on the other side?
yeah i know its the version with blanket fuel/ign adjustment, i used to borrow tommy fields monitor which is the same for when i run bp 102 fuel at thrashes to advance the ign for that little bit extra grunt
(ign advance was pre determined from a set up session with afr monitor and det cans etc not just advanced without checking the safe limitbefore anyone says)
i only run it on the car for a couple of minutes and didnt start a new logging session so il ty that tommorow maybe after a run incase the monitor is just sayng the last stored loggin is corrupt due to battery flat as it hasnt been used in a long time.
can anyone remember what dial does what on this version as its been ages since i last used tommy's mapping version?
i will also ask mike r about battery
Almost there!
Looking like youve sourced a nice unit there Mark.
Ryan, hope that wasnt my plug you used
Mark, that was me that was talking to you about the pectel monitors for 5 mins in the firing up lane at the pod last weekend
Rally nut
Sorry mate can't help with the battery, but happy it seems to suit your needs, as said the others quite rare monitor and for the price I sold it, well you've made a nice bargin.
Hope you will solve this small "problem" soon.
mk3ste
17-10-2021 10:09 AM
rsguy
44
29-09-2015 03:29 PM
