cossie 4x4 brake problem Need Help ASAP.
hi guys i have a weird problem with my cossie at the moment, when i use the brakes sometimes the pedal goes rock hard it's done it when ive just started the car and then it goes back to normal after 2 mins. but today it done it when i was driving it's like trying to push a bolder into the ground with your foot.can anyone give me any ideas of what it could be?cheeRS.
1 Post
Try 30amp fuse under the front wheel well, i had this rock hard pedel, brake biting point no the same all the time, made it swcary, there are 2 30amp fuses for ABS in the foot well
Resident Wrestling Legend
when it goes rock hard it's the pump over pumping
pressing the pedal releasing some of the pressure which is why it might get better after a few minutes
fuses going potty are one thing that springs to mind, but you might also need to look at the condition of the brake fluid and also the pressure switch in the pump as this can also cause problems, especially as they tend to be fairly heat tempremental
the orange light comes on sometimes then it'll go out. the bloke at the local garage reckons that on cossies you should here the brake system under the bonnet prime or make a bussing noise when the ignition is turned on but mine has stopped doing that.
1 Post
Check the Fuses under the well, Go and do it buddy, it may be the issue, i have known 3 cossies so far with the same issue and one of the 30amps had blown on all of them
as when i bleed my barkes, the pedal is rock solid now
the car stops etc fine, but there is no movement in the peddle at all after bleeding them its just solid
wondering if its over pressurising
as that sounds about rite
any cure for this as it could be doing what this one is doing
also the pump should prime when igntion is switched on but only for a couple of seconds
1 Post
sounds like the power to the abs pump is not there, i had the wires to mine break internally under the insulation, they had wrk hardened and with teh battery being on and off the car so often , withte the wires being bent out of the way , they had broken off leaving the insulation intact, only found it by doing a 'waggle test' on the loom, had to chop back about 6" on the power feed to the pump from the pos feed off the battery.
jason_nike
18-08-2019 10:53 AM
Red_bull
09-08-2015 08:34 AM
