what boost does a pectel monitor see up to?
my secs monitor only reads upto 29.3 psi so comes up alarm warning so il have to turn it off,
but what do pectel monitors read up to on the boost sensor? is it just whatever the map sensors limit is you have on the car?
cheers
marc
cheers
marc
Testing the future
the SECS monitor is slightly different in that it is not using the internal ecu analogue to digital conversion and filtering as it takes the voltage from the MAP sensor and converts it to a digital number inside. but you're still limited by the range of the MAP sensor and the scaling of the A/D conversion
Testing the future
contact boschman (IMA or phil or whatever he is called these days) for a price, but yes you will need a remap as the ecu needs to know that you have changed to a 5 bar otherwise your 2 bar of boost that would have been full scale on a 3 bar MAP will only be about half the voltage of what it was (so your ecu will only think that you have 1 bar of boost and so will dangerously underfuel etc)
Mark RS
12-10-2015 06:01 AM
Russ Payne
25-09-2015 08:29 PM
