mounts??
Old Apr 14, 2008 | 01:28 PM
R5FORD's Avatar
R5FORD
Default mounts??
where can i get new engine and gear box mounts for the 2wd saph?
cheers aaron
Old Apr 14, 2008 | 01:54 PM
Dan@Rapid-Ford's Avatar
Dan@Rapid-Ford
Are you after standard ones or uprated? We can supply the Vibra-Technics ones for 2WD. Let us know if you want a price.
Old Apr 14, 2008 | 01:57 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
http://www.randbmotorsport.co.uk/shop/Parts.asp?ID=28
Old Apr 14, 2008 | 02:03 PM
R5FORD's Avatar
R5FORD
Mike do you have standard gearbox mounts?? as im trying to loose vibaration, not gain more
Old Apr 14, 2008 | 02:07 PM
Mike Rainbird
Caraholic
It's very rare for these to need replacing on a 2wd, so are you sure you need to? I even had standard ones on my 515bhp Sapphire... .
Old Apr 14, 2008 | 02:16 PM
R5FORD's Avatar
R5FORD
erm im not 100% percent sure
but im gettig alot of vibiration when going hogher through the rev range, so i was going to change them all
Old Apr 14, 2008 | 02:18 PM
Mike Rainbird
Caraholic
More likely to be a poorly adjusted turbo damper .
Old Apr 14, 2008 | 02:24 PM
R5FORD's Avatar
R5FORD
il remove it tomorrow and see if it gets any better, could one of the engine mounts be gone if its not the damper?
Old Apr 14, 2008 | 02:31 PM
Mike Rainbird
Caraholic
Possibly, but I still think it is the damper. If you remove it, it will get worse . Swap the one off the RS500 onto it and see if it gets any better .
Old Apr 14, 2008 | 02:34 PM
R5FORD's Avatar
R5FORD
my damper setup is erm not standard anymore i have a bailey damper and thats connected to the turbo via a bracket that i had to have made up. i got the exhuast set up a while ago and the vibiration went but after a few ays came back.. not sure what it could be. is there anyway i can check the engine mounts?
gcfcos
59
Oct 6, 2015 05:04 PM
rsguy
44
Sep 29, 2015 03:29 PM
DavidK
Sep 27, 2015 02:55 PM
IainRS1700T
Sep 25, 2015 06:44 AM
Andypandy260
Sep 23, 2015 10:28 PM
