Can you solder on glass?
The rear heated screen hasn't worked on my wifes golf since she bought it, I'd checked the normal stuff but couldn't work out why it didn't work. I've just gone to move her car and I noticed one of the wires was hanging off and on closer inspection I noticed the connection must have come away from the screen in the past and been stuck back on with glue
Is it safe to solder it back on or will the heat pop the rear screen?
PassionFORD Member
suppose it depends on the temperature. i've seen somebody welding a roof rack before on top of a defender landy and all it took was one spark to pop the rear screen but thats from a mig welder. if you have VERY neat soldering skills you can try it and cover the surrounding glass area with cardboard and masking tape or something and leave a tiny tiny area for your soldering
I'll take a trip down Maplins tomorrow dinnertime and take a look otherwise I'll give a go I've got nothing to lose except the rear screen
The tiny amount of heat from a soldering iron will not break the screen.
Rough up the area and use PURE SILVER SOLDER, and it will take fine.
But as said if fully comp phone around as companies can kill the xcess dependingh on who you are with and the screen limit, as some are very low, other wise not expensive anyway, and easy to do DIY with a s/h one.
I got the stuff from Maplins but the line still doesn't work.
To remove my first attempt I scraped it off with a knife. Anything else I should try before the third attempt so I get a good connection?
Resident Wrestling Legend
you'd still be soldering at an angle upwards rather than downwards
why don't you get get the tape that they flog in places like halfords where you can just put it across and make it look nice and neat?
or just get another screen put in that works
07-10-2015 12:56 PM
