any diesel experts about
hello i was wondering if any one could help ? does any body no what would cause this the vehicle turns over but doesn't fire at all if you tow it or bump it it will start then for the next few hours it will start off the key then after a few hours it will just turn over then not fire like before. when it comes to diesel I'm clueless any help would be much appreciated the vehicle in question is an n reg transit
could be Air in the diesel system or the diesel pump itself could be faulty, any leaks around injector pipes, leak off pipes?
you didnt run out of diesel recently did you?
no never run out of diesel nothing has been changed or messed with one day it was fine the next day this happened no leaks that i can see. and like i say when you bump/tow it it runs fine and fires off the key but until you bump it it don't even attempt to fire its confusing
DavidK
27-09-2015 02:55 PM
