Max BHP on cosworth t3 turbo ?
tried the search function but 't3' is too short a search term to be searched for...
so as the thread title... whats the max bhp you could see using a cosworth t3?
thanks in advance
thanks in advance
cheers... its not actually going on a a YB engine, but just curious as to what he could be looking at producing if all goes perfectly to plan.
saff is working!!!...atm
.........sorry mate but that just sounds wrong...................and Ben if it's not going in a cossie then how the fuck do we know what it'll make...???.............is it going in a.....mini.......a gsxr 1000.............a horse n kart......................
Having spoken to Stu and him doing the chip on my car, peaking at around 26psi he is confident it can make a genuine 310bhp Ben
Mine is on 803's, 4x4 'cooler and Grp A Headgasket, everything else completely standard
Pete, I wasnt convinced by it either but I had a graph saying it was.
As long as my cars are set up fine I couldnt give a monkeys what the figures are anyhoo. Id have said it was more likely to be just over 300 on that one tbh. It used to shift canny though so that was fine by me. Lol.
Piss taker
I think he asked this on my behalf. He's getting excited enough for the both of us!! lol
My spec is:
2.1 Zetec Turbo
Eagle Low comp pistons (About 8.5)
Eagle Steel H-Section Rods
arp conrod bolts
440cc/min Injectors
Hybrid Cosworth T3 with 360Bearing, I needed an extended actuator rod so I'm guessing it could be a 4x4
-31 actuator
3bar map
Pro Alloy front mount intercooler
Pro Alloy alloy rad
Cosworth fuel pump
Stage 2 CTS Gearbox
AP PAddle Clutch
Emerald ECU
Magnex 2.5" Bore Exhaust
Wideband Lambda
EGT
300bhp and similar torque is the target. Time will tell.
My spec is:
2.1 Zetec Turbo
arp conrod bolts
440cc/min Injectors
-31 actuator
3bar map
Pro Alloy alloy rad
Cosworth fuel pump
Stage 2 CTS Gearbox
AP PAddle Clutch
Emerald ECU
Wideband Lambda
EGT
I'm surprised by those figures, I've got a t3 on my 2 wheel drive and I'm fitting a pace rs500 intercooler, dark greens, 3 bar map sensor & Ahmed Bayoo stage 3 chip and I was hoping for 330bhp I've also got a panel filter & system on there and I'm going to be using Mark Shead to set it up, looks like I'm going to be disappointed
My spec is:
2.1 Zetec Turbo
arp conrod bolts
440cc/min Injectors
-31 actuator
3bar map
Pro Alloy alloy rad
Cosworth fuel pump
Stage 2 CTS Gearbox
AP PAddle Clutch
Emerald ECU
Wideband Lambda
EGT
My spec is:
2.1 Zetec Turbo
arp conrod bolts
440cc/min Injectors
-31 actuator
3bar map
Pro Alloy alloy rad
Cosworth fuel pump
Stage 2 CTS Gearbox
AP PAddle Clutch
Emerald ECU
Wideband Lambda
EGT
What cars this little lot in then? As if your from Shields I'll have to keep my eyes open for it
i can vouch for that as the car in question i used to own and yes it did shift canny big time
My spec is:
2.1 Zetec Turbo
JE Low comp pistons (About 8.5)
arp conrod bolts
Rover M16 inlet manifold
Custom tubular exhaust manifold
440cc/min Injectors
-31 actuator
3bar map
Pro Alloy alloy rad
Cosworth fuel pump
Stage 2 CTS Gearbox
AP PAddle Clutch
Emerald ECU
Wideband Lambda
EGT
My spec is:
2.1 Zetec Turbo
arp conrod bolts
440cc/min Injectors
-31 actuator
3bar map
Pro Alloy alloy rad
Cosworth fuel pump
Stage 2 CTS Gearbox
AP PAddle Clutch
Emerald ECU
Wideband Lambda
EGT
yup
simple... i didnt ask what power it'd make on the engine i was thinking about... i just asked about how much bhp it could actually flow the air to produce, so what ever engine its bolted to wouldnt alter that figure... if it did compressor maps would be completely useless
Thats old money mate, people quoted that at Stg 3 330 bhp conversion when in reality it aint...
I am sure Mark will do the biz tho
