hub convertors? how easy to make?
Right basicly i have found some wheels i want to buy for my fiesta but they are not 4stud 108pcd as there of a focus WRC rally car
How hard will it be to get hold of hub convertors to make them suit my mk3 fiesta?
also does anyone know what pcd are focus WRC wheels? (the o.z mag type)
you wont need hub convertors, you could remove your hubs and have a machine shop drill the new stud pattern into your hubs, you would also need the brake discs done to suit too.
so when finished your hubs will have the standard stud pattern and also the stud pattern to match the new wheels, meaning the hubs will now have 8 holes in them.
all the above is assuming the focus wheels are 4 stud and not 5 stud
ah, is it that simple? there going on a mk3 fiesta hopefully. There going to be my track wheels.
Ive won the wheels in question now anyway
http://cgi.ebay.co.uk/ws/eBayISAPI.d...MEWN:IT&ih=020
will collect them tommorow if possible then i will be able to tell how much work will need doing to get them to fit
i will be able to update on my ideas when i get the wheels.
i have a idea on how im going to do it but not sure if its possible till i get hold of the wheels.
its only a track slag anyway so not the end of the world, the o.z can go back on ebay if needs be
thanks matty
well i picked up the wheels yesterday
measured them today and the focus studs are 5 1/2" apart (diagonaly)
And the standerd ford 108 pcd there are 4 1/2" apart (diagonaly)
so there not as far apart as i first thought, i think it will be fairly easy to get some convertors knocked up.
Now the et on them is 52, what is a standerd mk3 fiesta? will need to know so i dont get them stupidly wide
Adam Graham
06-09-2015 06:04 AM
