General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
Managed to find a bit of spare time to carry on with my rebuild on the rwd saff.
Fired it up for 10 mins or so to bed cams in sounded very very healthy
Spec is as follows;
YBP Late escos engine
.5 over size cosworth racing low comp pistons.
ARP con rod bolts
STD size crank
Lightly skimmed head and block
Fully balanced bottom end
Ported and polished head
ISKY valve springs
BD14 inlet
STD exhaust cam
Cometic head set
STD headbolts
Sweedish inlet
2WD exhaust manifold
Manifolds matched
Kent verniers
GRP a coil
All new sensors
TT T38 turbo
RS500 cooler (pace)
APEXI boost controller
Gonna run in on std injectors/chip.
Then its gonna be 82 lb siemens injectors
044 pump
live remap
Looks like a right nail under the bay, but thats the idea this year. Keep it looking rough whilst i sort all the oily bits. Just to suprise the sniggering m3 driver
No ides mate i have double checked timing and sensor gaps. Sounds sweet for about ten seconds then it looses its idle, gonna phone stu today see if he can send me a pre live map chip to go with the new spec. The car is on standard yellows and stg 1 chip.
Ordrering injectors from usa and i have had a change of mind on the inlet, im gonna port my standard one on the restrictive throat and use a 10mm spacer.
