what would cause juddering.....
saff is working!!!...atm
when turning (mainley right hand down) on long bends.........just put 4 tyres on and noticed the fronts were worn on the inside edge.......i've had the tracking done but i think it hasn't been done right.......cheers
You mean they are now new tyres ? i.e. no strange wear ?
I had a similar thing on my merc and changed
front discs
rear discs
front wheel bearings
anti roll bar links
lower ball joints
had tracking done
then............. noticed the two front tyres were worn on the inside, changed them and job done
Was nieve to it as I couldn't see how tyre wear alone would give the car the shakes.
front discs
rear discs
anti roll bar links
lower ball joints
had tracking done
Passion for Fords!
cv joint are nothing to do with mot.
cv boots are testable if they are split....but not the joints unless like some real old lotus cars,the shaft holds the suspension together
cv joints,and inner joints are very common problems on 4x4 cossies,they are at a stupid angle,and lowering makes it worse....also check engine mounts,as they split and allow the engine to lift,causing shaft issues
..............the garage i use knows to "fix all problems"......but will pop in and have them check.........the cars not on it's arse.....koni&AB height....and it's got collins uprated mounts.....(on since rebuild...15k)........cheers for ur help....off the garage again.......
had the tracking done again....it WAS out,so hopefully that'll stop the tyres wearing.....but it hasn't sorted the judder..................bugger
.......nup...next question.....i asked the lad who m.o.t'd it and he said he checked the front end of the car with a bar and everything felt ok......so i have to drop it off again for another look
