AP paddle clutch question
On a cossie version ?
I can messure tonight if no one else has responded, I have one in its box sat at the side of the downstairs loo
I have one that supposed to have done about 2500 miles and the paddles look like they have hardly any meat on them compared to my standard ford AP clutch (with considerably more mileage) so I'd be interested to know as well.
Also the flywheel that was with the clutch has been worn down a bit (you can see a ridge where the paddles end)
would I be better my other flywheel that was with my OE clutch or is this just how they end up with paddle clutch?
sorry yeah 2wd cossie
rsnissan
that's the reason i'm asking, i've got a ap clutch which has meant to have done less than 500 miles, but the contact pads look as if they havent got much 'meat' left in them. Not sure if that's how there meant to be or not!?
rsnissan
A paddle clutch will only generally last 7500-10000 miles on a cable clutch system...I went through two paddles in 12000 miles in my 2wd saff .
How far away from the face of the pad are the rivets? If it wears down to those it will trash your flywheel a treat..
Buying 2nd hand clutch parts is a very false econamy IMHO
