Closed loop question...
Old Mar 24, 2008 | 11:50 AM
Karl 3dr's Avatar
Karl 3dr
Default Closed loop question...
I'm taking my car to MSD in a couple of weeks time for a live map and closed loop fuelling , i was just wondering what sort of differences i should expect as far as the closed loop is concerned?
Does it make the car drive differently etc??
Cheers, Karl
Old Mar 24, 2008 | 11:57 AM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
.............ur dodgy old saff will drive like a brand new mondeo when it comes out of msd.................cloosed loop system helps the engine to stay clean and should give it a longer life.........aswell as 30mpg if u drive it off boost..........
Old Mar 24, 2008 | 11:58 AM
KSA-Cossie's Avatar
KSA-Cossie
Amazing difference to it made to my saph m8,wasted spark helps too.
Old Mar 24, 2008 | 12:36 PM
Karl 3dr's Avatar
Karl 3dr
Very tempted to go wasted spark as well, cant wait to get it all done, i've heard lots of good thigs about closed loop, is it true that it can reduce oil consumption as well because of the reduced bore wash?
JTECH James's Avatar
JTECH James
Passion for Fords!
more like 38mpg if you drive like a fanny
deffo less oil use
Old Mar 24, 2008 | 12:39 PM
rst in breaking's Avatar
rst in breaking
im glad to hear this as im having it done on my zetec turbo, what is needed a wideband sensor and? ive got the ecu to run it but dont know what is required? cheers
Old Mar 24, 2008 | 12:44 PM
JTECH James
Passion for Fords!
narrow band, i run L8,and msd software...
Old Mar 24, 2008 | 12:53 PM
Tev's Avatar
Tev
Best thing iver ever done 2 my car was take it 2 stu for waisted spark and closed loop, car runs like a dream, drives like a new car and the savin on fuel n oil is worth it alone
Old Mar 24, 2008 | 12:57 PM
rst in breaking
isnt wide band meant to be more accurate though? or am i wrong?
Old Mar 24, 2008 | 01:01 PM
JTECH James
Passion for Fords!
wideband is for a gauge,and has wider scope,
narrowband is used for closed loop,and measures the center area only,around 14.7;1
Old Mar 24, 2008 | 01:15 PM
costina's Avatar
costina
Live long and prosper!!
Best conversion out there imo i've both closed loop and wasted spark pulls smooth all the way with no hessitation or miss fireseen 150+ miles from Ł30 (driving sensible as always)
MSD
Paul
Old Mar 24, 2008 | 01:32 PM
Ginge !'s Avatar
Ginge !
just finding my feet
tbh getting your car back from MSD transforms the car anyway !!!
paul look into what a closed loop conversion actually does, its for part throttle driving/cruisng on motorways off boost, on boost the car will still be bad on fuel !!!
the remap will affect the way the car drives if theres a bad map on the car ( cossie motorsport chip on greys for example)
my car felt ALOT better when it came back from MSD and it just had a custom chip fitted to it, no closed loop ect, he just tided the fueling and ignition maps and the car performed better !!!
Old Mar 24, 2008 | 01:38 PM
rst-g's Avatar
rst-g
ZETEC TURBO
will it work on a zetec turbo with pectel t2?
Old Mar 24, 2008 | 02:19 PM
lamb chops's Avatar
lamb chops
So whats the diffrence to the standard 4x4 cossie closed loop? not stiring the shit but have allways wondered, is this just retro fit for the older cars?
Old Mar 24, 2008 | 02:21 PM
Ginge !'s Avatar
Ginge !
think its to retro fit, oh and the later 4x4 cars have a cat to help emissions too but thats nothing to do with it
Old Mar 24, 2008 | 02:49 PM
JTECH James
Passion for Fords!
the later emissions model cars(green top) had closed loop and cats
Old Mar 24, 2008 | 03:47 PM
KSA-Cossie's Avatar
KSA-Cossie
My k plate had the lambda etc in place,saves a bit of cash.
Old Mar 24, 2008 | 03:53 PM
rst in breaking
i know what it does mate but am not to sure what is needed? i have a narrow band sensor on my t34 already, is this all thats required other than a management to take it which i have and if i put a windband in the exhaust it will monitor egt and thats it? sorry for sounding thick guys but dont really know what is needed for this as yet
Old Mar 24, 2008 | 04:04 PM
Ginge !'s Avatar
Ginge !
i ment understand EXACTLY how it does it, not just guess
all cars these days have closed loop as standard, any car with a cat and some without, even diesels have it these days
if the ECU has closed loup control, then its just another sensor, just like a air temp/water temp sensor
AFR gauge does not measure exhaust temp !!!, its measures the air/fuel ration ( like a breathaliser for a car )
how do you know you have a narrow band already in the T34 ???, btw lambda sensors all differ from ecu to ecu, you cant just get one from a punto and plug it in the mangement
the wideband AFR gauge is just that, just like a boost gauge, you dont use a narrowband gauge on a turbo car as it dont cover the same range that a turbo car has ON BOOST so will register wrong readings
Old Mar 24, 2008 | 04:12 PM
rst in breaking
ive been told by emerald to use a vw lamba, and when i spoke to msd and emerald i was told the sensor i have in my t34 is more than likely a narrow band? anyone got any links to reading up on this? cheers
Old Mar 24, 2008 | 04:18 PM
JTECH James
Passion for Fords!
if it fits in the turbo,its the oe ford item like mine had from new...narrow band.
you do NOT need a wideband for closed loop,,they dont work.
you need a narrowband
Old Mar 24, 2008 | 04:28 PM
Ginge !'s Avatar
Ginge !
theres a few VW lamda sensors though !!!
you need a engine code for the lamda sensor your require
Old Mar 24, 2008 | 04:29 PM
rst in breaking
so the narrow band connects up to the ecu (just the sensor straight to the ecu) and the wideband goes straight to a gauge to monitor air/fuel ratio?
Old Mar 24, 2008 | 04:30 PM
Ginge !'s Avatar
Ginge !
do you have a wideband AFR gauge then ?
yes what you say is right
Old Mar 24, 2008 | 04:36 PM
rst in breaking
i want to pick one up, anything that can potentially save my engine by me noticing things in advance i dont mind spending money on
Old Mar 24, 2008 | 04:39 PM
costina's Avatar
costina
Most chips did'nt use the closed loop function after std due to the extra and time consuming programing hence why most if not all ran around 2.5/3 % co to run right
This is were MSD took the time to do this as 3% on tickover and crusie was a waste of fuel= bore wash, crappy plugs,rough running etc
which makes for a cleaner running engine which will pass MOT's without a hitch
As said this will only work on tickover and cruise so no more overfueling on tickover and puffing black out the rear
Paul
Old Mar 24, 2008 | 04:47 PM
RWD_cossie_wil's Avatar
RWD_cossie_wil
turbo cars will always be "bad" on fuel when you are boosting as you need the fuel there to mix with the extra air,just like if it was a 7 litre engine instead of a 2 litre engine. Closed loop tidies up part throttle, idle and cruise, and makes a world of difference
Old Mar 24, 2008 | 04:53 PM
Ginge !'s Avatar
Ginge !
will thats just what i was pointing out alot of people think " closed loop, i can rag the car and use less fuel than a vw polo bluefuel diesel"
just explaining its not the case,
if you use the car as a toy and rag the arse off it at weekends and have another car for the week is it actually worth converting a car for the closed loop conversion is what i wonder,
Old Mar 24, 2008 | 04:59 PM
Gatecrasher's Avatar
Gatecrasher
Not welcome...
Can you have Closed loop on T6 and Does the whoel car have to be remapped or can this just be added on?
Old Mar 24, 2008 | 05:47 PM
Billabong's Avatar
Billabong
T6 can run closed loop fuelling, not sure if it can use a narrow band on its own, but can use a wide band.
I think it just needs the lambda target table configuring to enable it.
What version of T6, Ben?
pete mcrash
....it's part of the chip/map....so u'll need a new set up
Old Mar 24, 2008 | 05:56 PM
Billabong's Avatar
Billabong
Pete, Ben's on about a Pectel T6 ECU, not a 'chip' / Pectel baby board.
Old Mar 25, 2008 | 01:16 AM
Gatecrasher
Not welcome...
Bang on Bill its pectel T6 2000
Old Mar 25, 2008 | 01:41 AM
RickyLee53's Avatar
RickyLee53
A narrow band is just used to trim fueling at light throttle.
An N/a car will still be out of range for the narrow band on full throttle.
Personally i removed closed loop and still get good fuel consumption. It just takes longer to set up, you basically just lean out the bottom end fueling to between 14.7-15.2 for better fuel consumption.
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Marv888
Sep 26, 2015 03:44 PM
pabloXR
Sep 21, 2015 12:42 PM
tib2220
Sep 14, 2015 12:33 PM
