Cosworth Oil Pressure
Old 19-03-2008, 12:29 PM
WD Pro
WD Pro's Avatar
Default Cosworth Oil Pressure
Hi,
What pressure does the standard oil pressure switch turn the light on / off at ?
What’s a typical cosi oil pressure at hot idle ?
I am looking at the oil plumbing / gauges for the Dax build and was wondering what was a safe level for setting them at.
Cheers,
WD
Old 19-03-2008, 12:32 PM
Graceland
Team HOTHOT!
Graceland's Avatar
7psi if my memory serves me right is what the pressure switch activates (ie, turns the light on/off) at
My old cossie hot idle I got 20-30psi depending on oil type and hot 3000rpm I got 60psi-70psi depending on what oil
Old 20-03-2008, 12:42 PM
WD Pro
WD Pro's Avatar
Anymore input ?
Wondering if I should get a 25 psi switch or if that would be a bit much for the nerves if it comes on after a good thrash ...
Cheers,
WD
Old 20-03-2008, 05:27 PM
Jimboxr4x4
Jimboxr4x4's Avatar
Mine generally idles around 20 - 25 when hot so 25psi switch might be a bit too high.
original
30-01-2022 08:20 PM
oilman
Trader Parts for Sale.
30-08-2015 08:37 AM
Adam-M
26-08-2015 05:53 PM
mrmann
20-08-2015 11:24 PM
14-08-2015 07:29 AM
Quick Reply: Cosworth Oil Pressure
