Gauges
it will be mechanical and electronic mate. the electronic use senders where as the mechanical ones dont. The electronic gauges tend to be more accurate (response time) as the pipes dont have to run all the way to the gauge (boost for example)
analogue will more than likely be electrical,so require a sensor then wire to go to the gauge,mechanical will simply have a vacuum line (if boost) or a fluid line (if fluid pressure) going to the back of the gauge.
Mark RS
12-10-2015 06:01 AM
wheelwizardrefurbs
22-09-2015 05:45 PM
