bmw e36 320i
Old Mar 16, 2008 | 01:06 PM
lloydwillard132's Avatar
lloydwillard132
Default bmw e36 320i
hello just wondering if any1 here knows what may be causing it to overheat.the obvious ones are air lock in the water system,and its got a e30 3.0l rad is there anythink else that could be causing the overheating.
Also what could be causing it to misfire checked the lamber sensor,checked coil packs,only other thing i can think of is a fuel starvation.
thanks lloyd
Old Mar 16, 2008 | 01:19 PM
big_wig_074's Avatar
big_wig_074
yeah,you will have a airlock,the system does NOT self bleed,use the bleed screw near where you fill the system,and fill the car while its running,this will sort it,had same problem on my 325.
Old Mar 16, 2008 | 01:23 PM
rst-g's Avatar
rst-g
ZETEC TURBO
water pumps fail on then thats what i would check for mate!!!
Oranoco
41
Feb 11, 2016 01:28 PM
Oranoco
12
Oct 2, 2015 02:18 PM
stevecfrst1
Sep 30, 2015 05:18 AM
`spotty
Sep 25, 2015 11:41 PM
Kam B
Sep 24, 2015 10:40 AM
