Can someone explain big end and little end?
A mate went to the garage and they said 'oh your big end's away' but we're not too sure what big end and little end mean and what exactly is wrong.
Any info appreciated
Big ends are refering to the bearing shells around the crank.
The little ends are refering to the bearing shells around the piston.
With poor maintanance and irregular oil changes these bearing shells can wear out, there is then movement in the con rod against the crank causing the knocking noise you here. Usually the only effective solution is either replace the crank and bearing shells or have the crank re ground and fit a slightly bigger shells in.
HTH
HTH
HTH
HTH
Indyrs
04-12-2022 12:39 PM
JK12
33
26-04-2021 12:09 PM
SMILER258
28-09-2015 09:04 AM
