help! 071 plugs for cossie
got a set of these plugs for the cossie but they are playin up - were brand new from matt lewis motorsport but car wouldnt start with them in - any idea if they are gapped from the factory and if not what should they be gapped at? Its a 1992 sapphire cossie running stage 1 - cheeRS
i also got a set off matt about 4 weeks ago and just put them in on wensday and i had to take them out and put me ngk's back in after a couple of runs as the car was running shit.......it was missing badley
tryed the gaps at .80 then .70 then down to .60 but still ran the same
If the spark is 'blowing out' on stage one boost, the problem isnt the plugs i wouldnt say mate..
PS: 071s are gapped at an angle IIRC.
my cos on MSD stage 3 with them plugs never ran rough even very cold.
would check your ignition system in general
crank sensor
leads, coil etc.
crank sensor
leads, coil etc.
I got mine from matt to and they needed gapped, remember only a tiny bit out and it can blow the spark out.
As PEE VEE said if it wont start im afraid its not just the case of plugs not being gapped, it would still start up but only be rough when you tried to power it up
My car i thought was ok till i reached about 5k then it started missing a little as if im hitting a rev limiter, gapped them to .6 and it was fine right to the red line
deathrider666
28-09-2015 06:12 PM
