battery tray...
Old 09-03-2008 | 01:16 PM
bonus_boy's Avatar
bonus_boy
Default battery tray...
i took out my battery yesterday as all around the tray it was filled with sealer and then sprayed...
i knew it was a bad sign anyway, but just wanted to see how bad..
so took the battery out, and the battery tray itself is fine, but underneath theres a hole!
probly about 6cm x 6cms, could i just chop the rust out and have a plate welded and then just put the original battery tray back in? is that how people do it?
first thing though..how the bloody hell do you get the tray out?
Old 09-03-2008 | 01:22 PM
Battery tray needs to be taken out by grinding, you can then fix hole, then weld in a new battery tray as they are very cheap.
Old 09-03-2008 | 01:25 PM
bonus_boy's Avatar
bonus_boy
would all this be able to be done under the bonnet or would the dash have to come out?
Old 09-03-2008 | 01:44 PM
Rossco's Avatar
Rossco
I dont think you would need to take the dash out, but you would need to remove carpet and sound deadening from under the battery tray.
Old 09-03-2008 | 01:53 PM
bonus_boy's Avatar
bonus_boy
yer, going to say ive spotted some sound deadening under the tray, as i was poking around...
so if i grinded out the tray, grind out all the rust and pull out all the sound deadening it should be ok just to weld in a plate and weld a new tray back in?
Old 09-03-2008 | 01:58 PM
stuey's Avatar
stuey
Mova battery to boot and patch over the hole, got a pic of the hole?
Make sure you grind as much of the rust away as possible.
Old 09-03-2008 | 02:35 PM
RAT8OY's Avatar
RAT8OY
Use a spot weld drill to drill out the welds holding the tray in place. This will leave it in good condition for migging back into position.
Take out your glove box if you want an easy life. Remove sound deadening under the tray, most of the time I cut this away as its a moisture trap anyway. Then cut out all the rusty metal around your hole. Weld new patch in place, seam seal inside and out. Paint all areas, plug weld the tray back in, touch up the paint with another coat around the new welds.
All good.
Old 09-03-2008 | 02:36 PM
bonus_boy's Avatar
bonus_boy
im thinking of moving it to behind the passenger seat, dont realy want it in the boot...
il go and take a pic now...
Old 09-03-2008 | 02:48 PM
bonus_boy's Avatar
bonus_boy
it aint letting me transfer the pics onto the computer..il try again inabit..
but basically theres a hole underneath the battery tray..
Old 09-03-2008 | 03:14 PM
stuey's Avatar
stuey
On the rear bench in a battery box would be be best, but behind the seat is fine to I guess
01-11-2015 06:53 PM
07-10-2015 12:56 PM
Fudgey
21
30-09-2015 06:19 PM
morg65
Escort MK 5 / MK 6
23-09-2015 08:57 PM
Flatlinedan
18-09-2015 12:41 PM
Quick Reply: battery tray...
