AFR Gauge
Custom
LC1 has worked perfect for me the thing is with the LC1 if has to be wired perfect and earthed properly it rather stop working than give a incorrect AFR output unlike some other kits
Almost there!
thats a bit Harsh Michael, im hoping thats the loving banter that you two deserve.
Rich what other options are there, do stack do somethings thats compatible with your requirments?
Live long and prosper!!
I use a LC1 works fine but the instructions and the wiring don't make sense imo once you have overcome that then great
Typical yank wiring and instructions but I got a good deal from GGR at £170 i can't complain
£213 buys you a stack from DT or cheaper from Mike looks trick
Paul
Paul
With regards to the thread title. There is the VEMS unit that Christian sells which for an extra £60 can also display EGT
Sponsor
there are endless faults with innovate afr setups !stu did coment on them on a thread a while ago that he found the same issuses i did and the most popular threads on the innovate site are faults anyway kev/phil bollox
rich try this http://www.zeitronix.com/ its been faultless for me in the last 3 years , in six months i went through loads of sensors using innovate stuff and controllers lol
Mark RS
12-10-2015 06:01 AM
wheelwizardrefurbs
22-09-2015 05:45 PM
