"99 spec" 200 Blocks
Does anyone know the kind of power/torque/spec the newer batch of blocks can take before it is an issue?
so possibly with long studding they *might* be ok (if it was due to head lifting?)
so would be ok on a T4 speced engine then? say round the 500 brake mark?
*** Sierra RS Custard ***
Im of the opinion that given that the casting shape is the same (ie they arent a different design) then the material used must be of a lower standard in order for it to fail, so Id expect long term reliability at a lower power level to be compromised as well, not just out and out power handling capacity, so consqeuntly I wouldnt use one myself, but Ive no real world data specifically about them failing prematurely to base that on.
I would measure the wall thickness on all 4 bores first.
Mine cracked in the tinnest bore, which was over half a mm thinner than the next thinest.
I think a normal 500 bhp engine will be fine but when thigs are pushed further it might become a problem.
