Any window/door fitters
In my dining room, I currently have an old wooden single glazed window. It leaks and wind blows in it, and rather than replacing it, I fancy fitting patio doors. I'm usually pretty good with DIY, and I dont have a problem cutting the wall out, altering the inside etc but I was wondering just how difficult it is to fit the actual doors?
Is it just a case of rawl bolting the frame to the wall and then silicone it?
Any idea what kind of price I would be looking at for a white uPVC (inside) with brown uPVC (outside) double glazed patio door. Probably a 2 door unit so around the 1500 x 2100 mark?
hi, they are easy to fit providing your walls are cut plum, although you do have fairly good tolerances for adjustment in the doors, the essence is having frame level, plum and square. once fitted use expanding foam around frame, let foam dry, rake off excess then mastic
Testing the future
dead easy. i had new windows and doors fitted in my house a year or so again and watched how they do it.
then last summer i cut the wall out of my coal shed to put french doors in to get the bikes in, and replaced the wooden window with a upvc double glazed unit.
got my doors from wickes on special offer. as above, fill gaps with expanding foam and finish with mastic or plastic trim strips if you desire.
the key is to get the frame fixed in vertical and square (measure the diagonals). b&q do pack of window and door fixings with the extra long plugs and screws, and you'll need a long masonry bit for the hammer drill.
you shouldnt have a problem, id put about 5 fixings in each side and depending on what your fitting will determine if fixings elswhere are required, if doors make sure the cill has a solid bed underneath
Excellent. I thought it would be fairly simple. I was getting quotes of Ł1200!!!! The doors I want are Ł350 so it did seem like a crazy amount of money for fitting.
I'll be making the opeing myself. The walls are no-fines concrete. FOr people who dont know, that granite in cement, with no sand. So I'll cut the hole and then tidy it up and make it nice and square.
RWD_cossie_wil
18-09-2005 02:33 PM
