Cable from Battery to Starter Motor
I need a new cable that goes from my battery to the starter motor what can I use for this without buying a loom any help/advice/links would be appreciated on what I can use
All it is are 2 cables,why dont you get one for an RST,Focus or Mondeo???Or make youre own,parts from here......
http://www.vehicle-wiring-products.e...e/homepage.php
Easy!!!!!!!!
Regards,Micky
Easy!!!!!!!!
Regards,Micky
Easy!!!!!!!!
Regards,Micky
Easy!!!!!!!!
Regards,Micky
What type do I get? cable size? Amps? cheers for help on this.
Battery & starter cables.
Red or black.
Heavy duty cables for main connections between battery and starter.
Copper conductors, PVC insulation.
These cables are also suitable for making up your own jump leads if our standard stock
does not meet your requirements (see battery clips & jump leads)
Prices are listed per metre but we can supply these cables to nearest centi-metre.
Ref Cable size mm2 O.D. Amps £/ metre Select Colour Enter quantity
126 126/0.40 16 7.5mm 110 £2.08 metres.
196 196/0.40 25 9.8mm 170 £2.73 metres.
315 315/0.40 40 11.8mm 300 £3.86 metres.
475 475/0.40 60 14.5mm 415
The biggest they do is
126 126/0.40 16 7.5mm 110 £2.08 red black metres.
196 196/0.40 25 9.8mm 170 £2.73 red black metres.
315 315/0.40 40 11.8mm 300 £3.86 red black metres.
07-10-2015 12:56 PM
muz
30-09-2015 08:29 AM
