Converting escos to rwd
Rubber Rhino Crew
Hi guys,
Thinking of buying an escos shell to put my running gear in but its all 2wd stuff so what needs doing to run the car rwd...
I have 2wd saph front x-member, 2wd sapphy rear beam, T5 box
I assume it's going to involve a gearbox mount and some sort of prop mod....enyone got info on this?
Dan
Dan
2wd front hubs 2wd front cross member 2wd gearbox 2wd steering rack 2wd shocks 2wd 2wd anti roll bar tca 2wd rear beam 2wd sump you need to use a custom gearbox cross member or use a modiyfyed 2wd one or use a escort cosworth one and you need to shorten the prop shaft all this is of the top of my head if i remeber any more i will add to it
oh and exshsut 2wd .proper side ways
Rubber Rhino Crew
You can use the Escort Cos ARB's (thicker and stronger, much better) but you need to use the Escort mounts and bushes as well . Prop-reon will do the shortened Prop for about Ł150 I think last time I asked , including a re-balance. Everything will bolt straight up as well . Exhaust will need to be 4x4 as well.
dan
You need to take a notch out of it if you want to run a speedo cable, apart from that it bolts straight on. Diva has the ford part code and they are only Ł20ish.
Rubber Rhino Crew
Hi guys,
Dan
Dan
Dan
Rubber Rhino Crew
Dan
Rubber Rhino Crew
Yeah I've spoken to Dave about the shell with the cage but he wants good money for it and i'd have to buy lots of bits to make it complete so probably mean another 2k to finish.
However the one I sent you a link to has all the bits needed...literally drop lump, x-member, t5 prop and rear beam and it's moving It's painted up nice and has full interior...seam welded etc....ticks all the right boxes just a shame about the 3dr shell we found you want it as a spare? know anyone who'll give me what I paid for it..shame to see it go to waste.
Dan
Dan
You will have to shorten the 2wd prop a little for it to fit. Off the top of my head I think it was about 60mm if I remember correctly.
turbotrev
39
17-04-2016 09:03 PM
