One for the mechanics
![Exclamation](https://passionford.com/forum/images/icons/icon4.gif)
Afternoon all,
Just got my car back from having some work done at a local garage that i've been using for years. Felt a bit weird so just checked everything and found the wheel nuts and driveshaft nut on the passenger side we're loose, in the case of the driveshaft nut not even finger tight! Sorted it myself now but my question is what do i do? Should i tell them, would you take being told ok if you'd messed up yourselves or do i let sleeping dogs lie?
Plus does anyone know how tight driveshaft nuts should be? I'm guessing very tight?
Sorry for the long post, thanks so much for your help.
It Wasnt Me!
Take it back, tell them the story, you sorted it but can they torque the hub nut and either put a split pin in it or knock the nut with a punch to lock it in place, no need to go mental but you got an exscuse to take it back and tell them!
cheers for your replies folks, will be going there tomorrow and not going mental or anything, their a decent garage and have never seen me wrong before now. Was only asking as I've never been a mech and just wondering how feedack is normally recieved?
how many other things are left loose? the best way is to do all the work you can on your own car.
im self taught and never gone to a garage. i say just grab the spanners and give it a go
it not hard being a fitter, the harder parts is things like tuning/costomizing and knowing all the technical stuff the rest is easy plus it's alot cheaper
Thats bang out of order mate and bloody dangerous and all !!!
I would expect to lose my job if i did that to someone's car, absolutely no excuse for leaving wheel nuts slack as the last and most important thing you do after working on someone's car is torque the wheel nuts !!! Very shoddy workmanship by the sounds of it mate and they must have used an airgun to tighten the wheels and forgot to tighten that one properly, if you are going back get them to check that all the others are tightened to the correct torque as well.
I would go fucking ape shit if someone had done this to my car as they have put someone's life in danger through their neglect and carelesness (sp!) !!
If its a garage you regularly use and intend to use in the future due to many previous faultless visits then I see no point in going mad at them personaly as you'll just be shooting your self in the foot long term. Go back, tell them whats happened and just ask them to recheck every thing else to be on the safe side. If they are reputable they will be very sorry, may even offer you some sort of reccompence for the future and the person who was responsible for the poor job on your car will hopefully be 're-educated', maybe with the aid of a big stick so that he may learn from their mistakes ![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
Or you could try the american way and just sue them
