escort cosworth ID??
Audio specialist
![Lightbulb](https://passionford.com/forum/images/icons/icon3.gif)
Hi peeps...
if i was to buy a ford escort cosworth shell that had no ID and had no numbers but had a recipt of sale from ford...
how would i go about getting ID and a reg number...
would it be Q-plated??
would it have an age-related plate?
any ideas????
any ideas????
Build it up with all new parts ( with receipts ) and register as a new car
If not speak to Martin Hadland, i'm sure he knows the ins and outs of it better than most
Audio specialist
*** Sierra RS Custard ***
biglee, apologies for the humour, can you give us a bit more info though, and then we might actually be able to give you a useful answer.
Is it a NEW shell with a receipt?
What parts will you be building it up from?
(ie new or secondhand)
Most likely answer is you will have to SVA it and get a Q plate.
if you buy a Brand new shell and "has not " ever been road registerd
for you to get it road registerd you have to fit brand new parts like brand new engine ect
If DVLA are happy with your car they will give you a new reg you can then register it what ever you want to call it then they give you a chassis number then you have to stamp it in normaly around the flitch
If you do have abrand new reg you will have to comply with new car regs
marco
marco
Audio specialist
right then...
it would be a shell used only on a track for track days...
it has a recipt from ford with the date and time it was payed for.
it has NEVER been registerd on the road or had any reg numbers afaik
it has been mot'd for the track by use of another 3dr car?(not sure on this tho)
it has many 909 parts on it and really is begging to be put on the road..
Hmm, bit of a grey area that one really, as technically it has to be a NEW replacement part in order to be used to reshell an existing escos and keep its age related plate, however, technically the point it becomes "not new" is when its stamped up with some numbers.
It might be possible, but I think you are on dodgy ground.
you need a badly crashed damaged (but not registered as scrapped) escort cosworth ID to use really TBH mate, done that way, it wont really get looked into anyway.
To register as new, you would need ALL new bits essentially, so very different to what you want to do anyway.
Audio specialist
ok.. i think i may have to look into this.. becuse if its possible that the shell has never been stamped... then i could go about getting new parts and even (dare i say it) cobbling up a few dodgy recipts from people i know in the MS industry.. and make it have a new reg... i can get a new block aswell, and mostly new parts ...
i dont think i would put it on another id tho..
can you put a private plate on a Q reg car Chip???
motorsport shells or a shell you buy from ford ..... do not have a chassis number at all unless you stamp one in
they only have a chassis number if they have been road registerd some point in it's life
a few people i know bought escort cos trimed shells yrs ago... they were 6k from ford
you got everything except for running gear and even these never came with chassis number
Audio specialist
thats interesting becuse this one does not have any stamped numbers... it has the plate but nothing on it... it hasnt been welded anywhere around it either..
so the best plan of action is to put it on another escos ID?
if you have a receipt for the shell,you could get it on a new reg,you don't have to have every thing brand new to get it, it work's on a points system, so you could use a second hand engine,if you can get receipts for new parts then you would make the points up no problem,but the part's must look new, regarding new reg must meet new car reg's i'm not sure on that, but i know a guy that built a westfield up with a vauxhall valver on t/b's it did not have cat's on it & it got a brand new reg, you would need to speak to dvla.
http://www.direct.gov.uk/en/Motoring...le/DG_10014199
they will have have a plate on the right handside of the slam panel
if it's a motorsport shell it will say on it there either group n or group a
909 *******
i dont know the best way to go around it is it worth going through the proper channels ? or do you use an exhisting ID ?
that is your choice
marco
Dont no if this will help my motorsport cozy was built from a bare shell,by a ford main dealers,for a customer origanaly to run in Group N but due to the final cost of bying every part brand new which came to a total of Ł44000 was never used,i have all the corespondents from DVLA about this car when it was ready to be registerd, and DVLA asked to see every reciept for parts ,which were supplied and which i now have 3 folders full .They also inspected the car twice before reg was issued, the chassis is stamped along with 909 vin plate, THIS WAS THE ONLY WAY DVLA would register the cars as new hope this helps sort of..............andy
right if the car ends up a Q plate it will stay that way and you cant put a private plate on ither the other way you are talking about is ringing the car you was saying about using escort cosworth id first do you have any idea what escort cosworth id sell for between Ł2.000 /Ł2.500 all day long and belive me it will be found out by the police ther is a few things i know about how the police get information on rung cars and it is shocking but its upto you but the second way is the easy way
DVLA will not tell you or allow you to stamp the old chassis number into the new shell. Instead, they will issue a new chassis number for the shell, then you go and get an MOT certificate using this chassis number.
Then you will need an SVA test and you give the certificates to DVLA in exchange for a registration number.
The points someone mentioned above kicks in for parts from a DONOR car, and if you have enough original parts they will either reallocate the donor's registration number or issue an age-related number.
How come the Quote function doesn't take an entire post any more?
well this is what i used to belive but ther is a dvla brunch run by police and i have had many dealings with them and i can say 1 thing is adding id to a unregisterd car is of high intrest to the stolen vhicle squad
Audio specialist
it has been done before by people on this forum and these people went to prison i believe.
Audio specialist
Was'nt there a escos for sale awile ago, White with stickers on it, think it was in a magazine aswell?? That was on RS2000 ID? How was that done?
Sunny
Sunny
