Seperating gearbox from engine
Old Feb 24, 2008 | 12:58 PM
Rippers's Avatar
Rippers
Monte Geek
Default Seperating gearbox from engine
Guys I'm struggling to get my gearbox out
I have all bolts undone, front arb lowered, exhaust off, rear beam/diff prop shaft off.
The gearbox has come away about 2cm but I can't move it any further
I've tried jacking up and lowering it, wiggling it and got the pry bars behind it... I just can't get it out
Any ideas or tips? anyone wanna come around and help
Old Feb 24, 2008 | 01:11 PM
Rippers's Avatar
Rippers
Monte Geek
Yes mate clutch cable is off, will try the WD40.
Shoud it be easier then this??
Old Feb 24, 2008 | 01:12 PM
Mark Shead's Avatar
Mark Shead
You have taken the gear stick cradle off and the pin out of the shaft that fits on top of the box for the selector.
Mark
Old Feb 24, 2008 | 01:19 PM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
Would be a good time to mod the box for hydraulic if that's a future mod.
Rippers's Avatar
Rippers
Monte Geek
I have taken the gearstick surround off but not actually removed the gearstick as was planning on lowering it complete but can remove if needed. The gearstick hasn't touch the edge of the inteior surround yet so I don't think it caught there.
What the best angle to have it out?
Old Feb 24, 2008 | 01:21 PM
Rippers's Avatar
Rippers
Monte Geek
Martin if the box is modded for the hydrolics can it still use the standard clutch cable untill I could get to where ever for the rest of the mods?
Old Feb 24, 2008 | 01:22 PM
Martin-Hadland
Yes.
Old Feb 24, 2008 | 01:23 PM
Mark Shead's Avatar
Mark Shead
The gearbox wont pull back any more you have to remove the pin and free the cradle off the box.
Mark
Old Feb 24, 2008 | 01:37 PM
Rippers's Avatar
Rippers
Monte Geek
Martin thats good to know
Mark I'll get on that next thanks
Old Feb 24, 2008 | 01:53 PM
dave cos4x4's Avatar
dave cos4x4
come on Paul, how is it supposed to move with gearstick still in.
Old Feb 24, 2008 | 01:57 PM
Rippers's Avatar
Rippers
Monte Geek
There's space all around the gearstick and its not even come out far enough to touch anything. I didn't take it off last time I removed the engine and gearbox still joined.
I'll try again with it taken off
Old Feb 24, 2008 | 02:02 PM
Martin-Hadland
You haven't got any pipework (breather/water) trapped between the top of the belhousing and the bulkhead have you??
Fil's Avatar
Fil
ELASTIC BAND
ive used a bit off wood in the past to get them appart, just easing it appart with a bit of leaverage.
Csm's Avatar
Csm
Yep gearstick off and some brute force
Old Feb 24, 2008 | 02:03 PM
dave cos4x4
the gearbox has got to go back a good bit to slide off the shaft,so the stick has to come off.
different if the engine is coming out,everything lowers down.
Old Feb 24, 2008 | 02:04 PM
dave cos4x4
is the speedo cable off aswell.
Old Feb 24, 2008 | 02:08 PM
Martin-Hadland
It's on the front driveshaft!!
Old Feb 24, 2008 | 02:11 PM
dave cos4x4
oops, so it is lol.
the times i have done gearboxes too.
Old Feb 24, 2008 | 02:58 PM
Franco's Avatar
Franco
Aint you got it off yet?
Old Feb 24, 2008 | 03:09 PM
Franco's Avatar
Franco
I had the phone call this morning Dave, but I was in bed watching American Chopper! ........
So I respectfully declined his offer!
Oh and I'm 30mls away!
Old Feb 24, 2008 | 03:16 PM
SteveB's Avatar
SteveB
Good choice.....
Lay in bed in the warm????
or...
Lay on the floor freezing ya tits off humping a 4wd box outta a car????
Steve
Old Feb 24, 2008 | 03:26 PM
Franco's Avatar
Franco
It was tough Steve...................
Old Feb 24, 2008 | 04:33 PM
RST-AndyP's Avatar
RST-AndyP
is this guy ok?He isnt laying with a gearbox on his head is he?
SmudgerByName
52
Jul 28, 2016 06:14 PM
van_dogg_pavvy
Mar 3, 2016 09:30 AM
3drRich
Sep 13, 2015 07:32 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
