cos rear diff rebuild?
Old Feb 20, 2008 | 04:41 PM
Lloyd's Avatar
Lloyd
escort mk4 cossy 4x4
Default cos rear diff rebuild?
i have been trying to rebuild the plated rear diff today,got it all back together but one side is further out than the other,it works and seems to operate ok,but is this ok,
Lloyd's Avatar
Lloyd
Old Feb 20, 2008 | 04:42 PM
Lloyd's Avatar
Lloyd
Lloyd's Avatar
Lloyd
Old Feb 20, 2008 | 05:04 PM
marco polo's Avatar
marco polo
hi lloyd
how have you held the input shafts in ? and why are you using a 7" version ? you will break it again
marco
Old Feb 20, 2008 | 05:09 PM
kitchy's Avatar
kitchy
RS2000 4x4
hi lloyd hope its sorted for monday, and what is happening monday ? pm me
Old Feb 20, 2008 | 05:11 PM
Lloyd's Avatar
Lloyd
hi marco,input shafts are bolted in. the 7 inch diff and adjustable rear beam where done when the car had the 420 bhp engine with anti lag.so would have been ok at that spec.
Old Feb 20, 2008 | 05:12 PM
Lloyd's Avatar
Lloyd
its tuesday now mate, pm ya in a bit
Old Feb 20, 2008 | 05:24 PM
kitchy's Avatar
kitchy
RS2000 4x4
cant do tuesdays
Old Feb 20, 2008 | 06:04 PM
Lloyd's Avatar
Lloyd
lol ok mate ,no problem.might see you sunday at the meet
Old Mar 18, 2008 | 06:16 PM
Lloyd's Avatar
Lloyd
Default update today
i have managed to sort the problem with the plated diff, i had 3 spare crown wheels,and thought they where all the same.so i used the best one i had,after much head scratching it appeared that the vanes on the original crown wheel and pinion had a slight taper towards the center,and the one i was trying to fit did not.changed them over and now its all working again.
Old Mar 18, 2008 | 06:43 PM
markk's Avatar
markk
i hope you havent just unscrewed the sides, removed the diff unit, changed the crownwheel and refit it ?
the CWP's are matched as a pair, the diff side bearings and the pinion will need to be reset for alignment and pre-load - if you havent don this it will rip itself to bits in a matter on miles mate
Old Mar 18, 2008 | 06:44 PM
markk's Avatar
markk
and is this not a gripper plated diff ? if so how the ffok ahev you managed to bolt the out put flanges in when the planet gear cross pin is inbetween the flanges ?
Old Mar 18, 2008 | 07:01 PM
Lloyd's Avatar
Lloyd
markk,i didnt realise the crown wheel and pinions where a matched pair.i have now fitted the original crown wheel and pinion..the output flanges are drilled through the center,and 8mm of bolt screws into the diff unit to hold the shafts in.
Old Mar 18, 2008 | 07:16 PM
markk's Avatar
markk
so what do the bolts in the middle screw into ?
when you fitted the castle nuts in on the side did you adjust the end float on the mesh between the crown wheel and pinion ? these hold shims and bearings for the positioning of the crownwheel, this must be reset everytime anything has been moved with the diff side plates
Old Mar 18, 2008 | 08:03 PM
Lloyd's Avatar
Lloyd
i will get you some pics of what the shafts bolt into tommorow markk. the pinion hasnt been moved,and i set the backlash? as it says in the manual.it all seems to be ok.
yatta
May 21, 2016 10:31 PM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
cossirob
Sep 3, 2015 09:17 PM
