General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
not a 500 setup, as the 500 set up had 4 injectors on top "ie" same as 2/4wd then another 4 on the face of chamber. Siamese twin injector set up or "wrc" as commenly known.....
..Yes i had same setup except i used the EEC4 plenum cover...apparently the best way of fuel delivery...I had no running issues at all and i beleive Mike R the resident bottom feeder stills uses it.
hi folks im planning on using one of these has anyone else ever used one if so are they any good and will a p8 run all injectors ta ??
Used the RS500 on P8 Super set up
(was thinking of selling the P8 Super ECU) and just doing the P8ECU 4 large set up with anti lag air 2 air and msn closeloop as soon as can be ased but not using on siamese but the RS500 set up so cant answer (the set you want to use )but 4 is fine and the spray patten / Mapping co can be done easier now days !
Would expect them to be fine and saves you a bit of cash to getting the RS500 8 inj set up
