2002 Puma - Door Open Light?
Hi Folks
On my wife's 2002 reg Puma, in the last week the orange "door open" light has stayed on constantly when the ignition is on/engine started. Obviously i've checked that the doors and the boot were shut properly and they are (and petrol cap...thought that may affect it)
I've looked at the doors and there is a push button spring loaded sensor on the hinge side of each door that gets pushed in when the door is closed, does this trigger the light coming on, or is there another sensor somewhere else? On the boot, there is a metal plate on the bodywork, then four metal spring sensors on the under side of the boot lid that press it when the boot is closed.
All the sensors seem to be moving freely, so it's not like one of them has got stuck.
I'm also pretty sure that it isn't the drivers door because surely if that sensor was showing the door was open, then the headlight buzzer would be going off constantly when the lights were on, which it doesnt
If anyone does have a Puma, can they check that the boot being open does make the orange light come on, if it doesnt, i can be pretty sure its the passenger door, which narrows it down at least
Anyone got any ideas about what i can try next? I fix servers, not cars
Thanks guys
Dave
Thanks guys
Dave
Baby Cheesus
its quite common mate, my missus puma does it too.
inside the door latches there are micro switches that often brake.
open the bonnet witht he ign on and press the plunger about 6 times, it should beep. then go round opening the doors and boot, and you should hear a beep each time. the one that doesnt beep is the fooked one - in my case its the pass door.
its only a few quid for the switch, but apparently its a pain in the arse to do, and i cant be arsed to it lol
STOP!... Carry on
its dead obvious mate... its springy and looks like a black thing poking up... if you can work it out from that you are agenius...
its dead obvious though mate! so best to just have alook!
ive not managed to look yet as my mrs is out at the moment, but i think i might know what you mean
its on the front and its like a little black plastic cone that pushes down?
borboyous
22-08-2015 11:17 AM
mrice0107
21-08-2015 07:55 PM
