Cleaning a YB Head
Right before i refit the head i want to clean the head, as there are alot of little bits of shit floating round in the top of the head, from either removal of parts or transport for it being checked, and also from me cleaning the head face.
The head is bare apart from valves & springs
My question is:
Can i degrease the head then power wash it or is that not advisable with the valve in?
Any advice would be great
My question is:
Guest
Posts: n/a
engine shop....ultrasonic cleaner bath ?? thats what i do....
from what good engine builders tell me thats "where the little devil resides", in getting all parts cleaned immaculate.....
its worth the effort cause eventually all u left in there will end up in your oil trying to lube the shells etc....so not good if left there....
yeah doug i've head they do a good job, although last time i use it for cleaning it stained all the white plastic bits in the dishwasher, that was at the old house and i tihnk the new dishwasher doesnt have any white plastic in it so i may be onto a winner.
hmmmm
that cup taste oily to you love
hmmmm
Surely the oilways are too important to NOT clean, all the above will not even touch the oilways.
If you look on the end of the head you will find at each end and under each cam a grub screw(aalen) blocking off the oilway that feeds the tappets, at the rearmost area WILL be loads of old congealed oil just waiting to float out and block something up, get some proper block cleaning brushes and clean these out, you would have enough here on a used head to half fill a egg cup, full of grit crap and old rubbishy bits, work front to rear, so you don't drag towards oilways which are all fed from here.
tabetha, cheers for the tip, the head is only like 6k since build so im hoping it not gunked up, but i might clean them as a matter of course.
not a clue where to get block cleaning brushes from, and to be honest sounds like a right hassle.
Think i just need to give a good clean to get rid of dust and gasket remants.
hmmmm
hmmmm
not as bad as me mate
i fucked the dishwasher.
brand new aswell
apparantly there is a pressure sensor in the bottom of the dishwasher to tell it when its empty and needs to stop pumping water out. This obviously got coated in oil, and stop operating thus making the pump run constantly, and overheating
![Red Faced](https://passionford.com/forum/images/smilies/icon_redface.gif)
she still doesnt know till this day, lucky it was brand new and under warrenty
the engineer even said to me, it smell very odd in the dishwasher
well the dishwasher worked a treat.
same scenerio though, spent the next 2hrs taking the dishwasher apart and cleaning all the plastic parts
