Vauxhall C16XE engine toque settings?
Hopfully start putting a C16xe together this weekend for the track Nova, just been having a quick look on the net for the toque settings for the engine internals and carnt find much, only the LET and 20XE settings.
Anyone help?
Anyone help?
1.4L - 1.6L 16V TORQUE WRENCH SETTINGS
Specifications subject to change without prior notice - issue date 25-01-07
MAIN CAP BOLTS (Standard & SBD Cap Head Type)
GRAPHITE GREASE UNDER HEAD,OIL THREADS
STAGE 1---37 LB/FT
STAGE 2---45 degree
STAGE 3---15 degree
BIG END BOLTS
Standard Type GM Rod Bolts
STAGE 1---18 LB/FT (GRAPHITE GREASE UNDER HEAD,OIL THREADS)
STAGE 2---30 degree
Heavy Duty Rods Bolts for Standard Rods -See separate instruction sheets
RB2K, RB2K-F, RB4, RB5, RB6
NOTE: - When assembling the bolts, as of 2002, the manufacturers recommend only using ARP assembly lubricant as supplied, under the heads and on the threads and torque up to. These are lower torque settings than would have been used with normal oil. We cannot be held responsible for rod bolt stretch when an uncalibrated torque wrench has been used.
OIL PUMP BOLTS
4 LB/FT(242 LOCTITE)
CRANK BOLT
GRAPHITE GREASE UNDER HEAD & WASHER, OIL THREAD
STAGE 1---70LB/FT
STAGE 2---30 degree
STAGE 3---15 degree
CAM CAPS
6 LB/FT
CAM PULLEY BOLT
48 LB/FT(242 LOCTITE)
CAM VERNIER PULLEY BOLTS
14LB/FT
IDLER PULLEY BOLTS
18 LB/FT(242 LOCTITE)
CAM BELT AUTO TENSIONER BOLT
15 LB/FT
SUMP BOLTS
242 LOCTITE
STEEL SUMP---4 LB/FT
ALLOY SUMP--6 LB/FT
DRY SUMP-----10 NM
STANDARD FLYWHEEL BOLTS
242 LOCTITE
STAGE 1---26 LB/FT
STAGE 2---30 degree
STAGE 3---15 degree
ARP FLYWHEEL BOLTS
35 LB/FT with ARP Lube
45 LB/FT with engine oil
CYLINDER HEAD BOLTS for Standard gaskets
GRAPHITE GREASE UNDER HEADS & WASHERS, OIL THREADS
SEE BELOW FOR TIGHTNING SEQUENCE
STAGE 1---18 LB/FT 25NM
STAGE 2---90 degree
STAGE 3---90 degree
STAGE 4---90 degree
STAGE 5---45 degree
HEAD STUDS (BLT-H3-STUD-KIT) for Cometic gaskets only
Due to the difference in quality of both Genuine and pattern standard head bolts, these are not suitable, therefore we can only recommend the use of the ARP HEAD STUD KIT when using a Cometic gasket. The torque settings and instructions below must be followed:
IF COOLING MODS HAVE BEEN DONE THEN THE COMETIC GASKET MUST BE DIMPLED
ALWAYS wash the fasteners with cleaning solvent prior to installation. They come coated with a 'protective' coating, this is NOT a lubricant.
METHOD
Supplied ARP lubricant must be used on all threads and underneath face of nut.
BEFORE CYLINDER HEAD IS INSTALLED: -
1. Ensure threads in block & on stud are completely clean
2. Apply lubricant to stud threads & screw stud into block finger tight only.
STAGE 1---25 LB/FT
STAGE 2---Back off ½ turn
STAGE 3---25 LB/FT
STAGE 4---60 LB/FT
STAGE 5---Back off ¼ turn
STAGE 6---60 LB/FT
ONCE CYLINDER HEAD IS INSTALLED, FIT NUTS & WASHERS - THIS MUST ALWAYS BE IN THE SEQUENCE SHOWN BELOW:
1. Pull up the nuts & washers to 25lb/ft torque & then back off ½ turn.
2. Repeat this twice and on the third time torque to 60lb/ft.
3. Back off ¼ turn
4. Finally torque up the nuts & washers to 60lb/ft.
STAGE 1---37 LB/FT
STAGE 2---45 degree
STAGE 3---15 degree
BIG END BOLTS
STAGE 2---30 degree
OIL PUMP BOLTS
CRANK BOLT
STAGE 1---70LB/FT
STAGE 2---30 degree
STAGE 3---15 degree
CAM CAPS
6 LB/FT
CAM PULLEY BOLT
14LB/FT
IDLER PULLEY BOLTS
15 LB/FT
SUMP BOLTS
242 LOCTITE
ALLOY SUMP--6 LB/FT
DRY SUMP-----10 NM
242 LOCTITE
STAGE 1---26 LB/FT
STAGE 2---30 degree
STAGE 3---15 degree
ARP FLYWHEEL BOLTS
STAGE 2---90 degree
STAGE 3---90 degree
STAGE 4---90 degree
STAGE 5---45 degree
METHOD
STAGE 1---25 LB/FT
STAGE 3---25 LB/FT
STAGE 4---60 LB/FT
STAGE 6---60 LB/FT
3. Back off ¼ turn
Originally Posted by Rossco
Proper bo
Cheers mate
Whens your Nova back at Woodbridge?
Cheers mate
until its quieter it won't be back lol, still waiting to get the proper engine back in it as its had a stock xe on tb's in it since before Chistmas.
track.focus'd
12-08-2015 05:53 PM
Zoggon
10-08-2015 10:39 AM
