4x4 Driving - Santa Pod - Veterans???
Not welcome...
May go to the pod this weekend weather depended but just wanted to ask a few questions if I may
First up what tyres would you use I have a set of TR1 Road Tyres that double up for my track wets and a set of 888’s which again double up for my track Slicks/dry tyres, now I know if its raining I will want the Road tyres but if its dry do I still stick with the road tyres or use the 888’s as I know the 888’s are the nuts on track but I wont be able to get much heat into them before running up the strip “and my cars only 330hp and 4wd so I cant do no big burn outs to warm them up”![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
Also I have seen in the past people saying they let air out of there tyres to make the car grip more, is this true, what tyre pressure did you find optimal and for what conditions?
also my suspension is fully adjustable and while I wouldn’t want to mess about with the height they do have 12 different stiffness settings so should I be making them Stiff or Soft or try and find a happy medium
Im also getting TRAMP on the car if i launch it at say 4 to 4.5K its queit bad and thna at 5ish the other day it wasnt as bad, is there a particular reason for this I.E. what Rpm I am launching at ect, I don’t know that’s why im asking
Im a total Novice and have never been to the pod or ran my car at anything like this ever so please bear that in mind with your replies “try not to flame me to much”
Thanks for your time
Ben
![Red Faced](https://passionford.com/forum/images/smilies/icon_redface.gif)
![Smokin](https://passionford.com/forum/images/smilies/icon_smokin.gif)
Ben
ELASTIC BAND
leave it as it is
give it full beens and dump the clutch when the christmas tree goes green!
no real help but it is almost 5 in the morning!!!
tho remember to have fun
Originally Posted by Danny B
I know a little about drag racing ![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
when ive done my saff,ive held at just over 5k and gone from there.any less and it bogged badly.anymore and it span the wheels.but tbh if you are using the 888's you will do better because i was on road tyres.
just enjoy it ben and dont worry anout the wobbly legs you get when you first pull up.you will be fine
Originally Posted by Fil
leave it as it is
Caraholic
Run the rear suspension on the softest setting.
Be careful of the tramp, do EVERYTHING you can to avoid this, as the shock loads from this WILL bust the rear diff's CWP
. I wouldn't worry about tyre pressures at this stage, as it is your first time, so just enjoy yourself.
If you want to achieve a good time, remove EVERYTHING out of the car you can unbolt (will make the car faster as well as being easier on the transmission) - this includes running with as little fuel as you can, as every litre is 1kg, so no point in running with a full tank of fuel, as that is almost like having another person in the car!
If you feel ANY vibrations through the steering while accelerating - call it an end IMMEDIATELY, as this will be the front CV joints / spider (needle-roller bearings) have collapsed and you will need to be able to limp the car home.
![Surprised](https://passionford.com/forum/images/smilies/shocked.gif)
MAD Carbon Cossie
Jus try different methods of launching & see what suits you best !
But above all have fun !
Don't listen to me tho bout launching, I can't to save my life !
What sort of time would you like to see or be happy with ?
The 60ft Launch King
Put the rear on the softest setting... Rev the car when trying to launch when the 2nd yellow bulb comes on.. over 5.5k the engine will change tune every so slightly... rev for one/two seconds allowing it drop down about 1000-500rpm before revving again.. try and aim for between 5000 -5500rpm or there abouts...
When you want to set off release the clutch when your rpm is revving upwards then floor the throttle. This hopefully will prevent bogging down off the line..
If you haven't gave it enough RPM you will bog down.. Give it too much and you'll spin the front wheels... get it just right and a don't fuck a gear change then you'll get a 12sec qtr without a doubt!![Top](https://passionford.com/forum/images/smilies/smile011.gif)
And if your gearbox breaks then don't blame me!
Not welcome...
Thanks for all the info guys am looking forward to having a bit of fun
My rear diff mount is uprated and 3 months old
dont worrie smith gearbox is full barra
Jb when i spoke to mike the other day he said i will tell you what your car will do "13.6" so 13.6 to beat and anthing below 13 will be fantastic
danny_B will run the 888's look forward to seeing you if you pop down
So when the lights green the clocks ticking or is it when you go past a certain point the clock starts?
Mike i know you said dont worrie about tyre preasure but what should i have as a rule then as i change to suit while on track so they could be at 28 all round from bedford is this ok?
Also its my B'day today so some family came down to see me and before they did i asked my pops if he could stop at burtons and grab me one of these
![](https://i137.photobucket.com/albums/q240/The_Gatecrasher/bensbirthday046.jpg)
Will be fitting this Asap and testing it out on me and fiecos dans test Track asap
best of luck
![Clap](https://passionford.com/forum/images/smilies/9c-clap.gif)
Not welcome...
is there anywhere i can leave the bits out of my car or say another set of wheels if i take the road tyres with me?
if i jump the gun is the run void or will it still time me?
is anyone else going next sunday?
If it is tramping bad when you launch you will break your rear diff, there is alot more grip at the pod than on the road. My mate did this in his 2wd saff with a knackered diff mount, stripped every tooth off the crown wheel
Not welcome...
im hoping with 330hp and 4wd on a 40/60 split its about 198hp to the rear diff and it is an uprated quaife
will be a little disapointed if it does break
the quaife bit does not remove the problem, the weak CWP and planets.... these are what will break.
And don't just sidestep the clutch, make sure you have wound the transmission up before you really go for it or you will break it, simple. As you stage, keep the clutch nipped, and hold the car on the handbrake to stop it rolling forwards, then when you launch the car has no slack in the transmission to lash..... , if you imagine all the little tolerances between splines, Cv joints, gears etc if you just sidestep the clutch you WILL break somthing eventually, just as Mad YUM
... I snapped a front shaft on std small turbo power on the road, as I came off the clutch quite sharp to get across a busy junction
Don't worry about the green, just get yourself set then launch, won't start timing until you break the beams
truffleshuffle
10-09-2015 09:35 PM
Adam Graham
06-09-2015 06:04 AM
