removing crank pulley?
Dave...
Buzz gun would be the best idea mate,and you will likely need a puller to get the pulley off once the bolt is out......DONT whatever you do hit it with anything,they are brittle as fook and it will snap like a carrot....
I`ve got a proper cosworth removal tool and a buzz gun if you can get it over to me....
Originally Posted by The Diva
Dave...
I`ve got a proper cosworth removal tool and a buzz gun if you can get it over to me....![Top](https://passionford.com/forum/images/smilies/smile011.gif)
Dave...
No probs mate,just give us a bell if you can make it over...
long bar with a socket on it (6 sided if u can) just try and give it a quick sharp hard tug. it should go after a few goes.
there is a thing u can but that bolts to the block with teeth on it that locks up the flywheel.
or try and wedge the flywheel against something (block of wood or similar) and get some one to put some weight on it then try undoing the bolt
as for the flywheel similar ideas really, just gotta try and get it to stay still while u put some pressure on the bolts.
a impact air gun will rip them all straight out for ya if u know anyone with one.
good luck with it
good luck with it
Dave...
Originally Posted by the youth
I once put a long bar on it and rested it on the ground then turned the engine on the starter
worked a treat lol but I don't recommend it
was on my old saph btw not my escort, I have grown up now and don't need to rush jobs on the escort!
steve
![Surprised](https://passionford.com/forum/images/smilies/shocked.gif)
steve
Team HOTHOT!
Originally Posted by picky775
Have you tried puttin a bar through cam pulley and lockin engine that way if the heads still on mate?
Resident Wrestling Legend
assuming the head is still on yes?
pull the plugs and put lots and lots of string down the bores until they fill up
then belt the engine to a study bit of solidness, i've got a 150kg bench made of 3 inch angle iron which does the job brilliantly
then just turn the socket
the string will compress up until a point and then it will lock solid and the nut will come undone
