Smoke when backing off? Turbo or rings?
Curse of the feature car re-appeared today!
Bit of blue smoke went letting off throttle, no smoke any time else, car drives perfectly and boosts perfectly.
More likely to be turbo or something more worrying? i.e. Pistons rings?
Any easy way to tell as I havent got access to a compression tester until monday!
Thanks!
Thanks!
easy solution si:
1) open oil filler cap
2) pour in 1 bottle of rad weld
sorted
hope u get it sorted or you'll have ur arse handed to u in the desert (santa pod)...........by paul that is
sorted
Blue smoke I would guess at valve stem seals.
I have fucked loads of turbos and mine have always let go with loads of white smoke never blue.
Have you pulled the rocker cover to see if you can spot crispy valve stem seal through the valve springs?
Good luck either way matey!
14000+ post superhero
3 times ive had lots of blue smoke when lifting off. turbo seals each time.
isnt blue smoke when idling or start up more likely to be stem seals?
Thanks for the help guys!
Rat8oy - Well it's bluey white smoke.
As in its not thick blue, just kinda bluey tinge
Its not as bad as when ive fooked engines properly before put it that way.
Turbo has done approx. 7000miles.
Head was rebuilt with new valve stem seals 4000 ago so unlikely to be them? I hope
Anyone know of anyone good to rebuild turbo seals in East London area?
Yep in that case perhaps the turbo then.
Bummer!
I dont know how handy you are with the spanners but I would prefer the rings TBH providing you are not talking an overbore and new pistons its not that hard to whip the rods out hone the bore and pop some new rings in. A good weekend at at and around Ł100 and your in!
Fuzzys point is very valid though but I have never had a turbo start to smoke (that certainly not to say it doesnt happen) mine have all just exited stage left via the exhaust!
Bummer!
Originally Posted by JTECHSAFF
a good test for stem seals is overun down a hill,and if it smokes as you hit the throttle at the bottom.....there fudged
Wont a little oil in the boost pipes show turbo if I have a look tomorrow?
Will it just get worse?
