MAP sensor question
Old Feb 9, 2008 | 04:23 PM
LHD220Turbo's Avatar
LHD220Turbo
Default MAP sensor question
currently my engine is standard, but i need a new MAP sensor
my question is: On a standard engine, can i upgrade to a 3 MAP bar sensor? will it run OK? - i'm pretty sure it will but i just want to check
i plan on going to stage 3 eventually so thats why i want to replace the standard map sensor with a 3 map bar sensor
cheers
Old Feb 9, 2008 | 04:52 PM
2001ode's Avatar
2001ode
Hi,
You can't fit a 3 bars MAP instead 2 bars MAP.
With each EPROM, you have an inseparable trio :
EPROM / MAP / Injectors.
You can't change only one element.
Regards.
Claude
Old Feb 9, 2008 | 05:27 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
you cant becuse the voltage/pressure ratio is different..
ie,5v on a 2bar may be 14.5psi
5v on a 3bar would be 29psi....
the max voltage the sensor gives is the same between the two sensor types
Old Feb 9, 2008 | 05:55 PM
As said, MAP values are co ordinated with chip settings so can't swap like this.
They have different pressure ranges, the 2 BAR has 17/216KPA, the 3 BAR has 17/308KPA, both have the same operating temp of -30C to +110C, response time is less than 7MS.
The 02/03(2 BAR) has an over pressure of 200%, whereas the 05/01 (3 BAR), has overpressure of 450KPA
Old Feb 9, 2008 | 06:12 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Thats the most eloquently put Ive ever seen the answer to that question.
Puts my english to shame
PERFECT answer IMHO.
Old Feb 9, 2008 | 07:08 PM
2001ode's Avatar
2001ode
Thanks.
Old Feb 9, 2008 | 07:13 PM
JTECH James
Passion for Fords!
not true though...std cossie....change eprom only=stage 1
no need to swap map sensor or injectors
Old Feb 9, 2008 | 10:07 PM
LHD220Turbo
bugger! - i've already ordered a 3 map bar sensor.
Anyone got a standard item laying around?
Old Feb 10, 2008 | 07:56 AM
Daveysaff's Avatar
Daveysaff
Skint Passionford User
Why not throw a set of greens and a new chip while you're there then?
Old Feb 10, 2008 | 08:21 AM
Moonstone Steve.'s Avatar
Moonstone Steve.
I think i have a standard one laying around somewhere m8,
Steve
Old Feb 10, 2008 | 09:24 AM
I have a good std one in my toy box!!
Old Feb 10, 2008 | 10:29 AM
foreigneRS's Avatar
foreigneRS
Testing the future
tis true - he is saying that for every chip you must have the correct MAP sensor and injectors
Old Feb 11, 2008 | 06:13 PM
JTECH James
Passion for Fords!
no he said you cant change one of the trio......
DixieTheKid
11
Jun 6, 2020 11:20 AM
wheelwizardrefurbs
Sep 24, 2015 08:35 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
wheelwizardrefurbs
Sep 18, 2015 02:39 PM
tib2220
Sep 14, 2015 12:33 PM
