compression test
Old Oct 16, 2004 | 03:26 PM
the strut brace's Avatar
the strut brace
Default compression test
what should the reading be roughly in psi (120 etc) for a newly built escoz engine with a .5 overbore , rough idea anyone??? mine is 120 but i notice on other cars some are higher and some are lower, does this change when you go low comp etc???
Old Oct 16, 2004 | 04:52 PM
St3V3_C's Avatar
St3V3_C
AFAIK you can't get an idea of the compression ratio doing this test, and will get variations from one engine to the next.
Do you think you have a problem? How was the test done?
Old Oct 16, 2004 | 05:07 PM
Toe Knee's Avatar
Toe Knee
Think mine were about 140odd but mine had standard compression. As long as their all the same then 120 doesnt sound 2 bad but best to see what 1 of the tuners says!!
Old Oct 16, 2004 | 05:13 PM
EvilFranky's Avatar
EvilFranky
My FRST when buggered had compression as low as 75psi on one of the cylinders...12psi of boost and 128bhp
Old Oct 16, 2004 | 05:17 PM
the strut brace
steve,i dont want to know the ratio, i just want to know if 120 is normal for an escoz, it was dopne with a mag tester that screws into the plughole, so if a normal escoz engine has 120, will a low comp engin have a higher psi or lower???
Old Oct 16, 2004 | 05:21 PM
St3V3_C's Avatar
St3V3_C
Was the throttle fully open? Hot or cold engine?
EvilFranky's Avatar
EvilFranky
Lower i would have thought mate.
Old Oct 16, 2004 | 05:23 PM
the strut brace
the engine was coldish and was being revved a little bit
Old Oct 16, 2004 | 05:25 PM
the strut brace
hey franky ,ive just noticed your frrom shields, u not come to our meetings at whickam m8?
TPM961
Jan 15, 2018 10:50 AM
Prickly_buzz
Dec 7, 2017 09:52 PM
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
Fezman1
Oct 2, 2015 01:22 PM
