Gearbox options - RST
Old 08-02-2008, 11:24 PM
  #41
Luca
Lukesville
Luca's Avatar
EXCUSE the works in progress pics but thats how much room you have between the box and chassis... loads and loads..
Old 08-02-2008, 11:25 PM
  #42
rst in breaking
rst in breaking's Avatar
nice work mate , any mods required to the linkage etc?
Old 08-02-2008, 11:32 PM
  #43
Luca
Lukesville
Luca's Avatar
Loose the linkage all together mate, just use focus gear lever/unit and the cables... Thats the easy part
Old 08-02-2008, 11:34 PM
  #44
Charlie Chalk
Unknown.
Charlie Chalk's Avatar
Hoe easy is it to convert to Cable from Rod linkage?
Or is it already cable
Im thinking of losing the rod on my car and going cable so i get a better position for gear changing!
Old 08-02-2008, 11:39 PM
  #45
Luca
Lukesville
Luca's Avatar
Depends on the transmission mate i think, i have removed all of the rod/linkage components from the gearbox/mounts through to the lever assembley itself and then fitted everything from the focus..
so its all focus cable operated just made to fit in a smaller space.
I would presume you would need a box that runs cables to begin with to do what you want.
Old 09-02-2008, 04:03 AM
  #46
Mixja
420
Mixja's Avatar
got a focus 6 speed sitting in me garage, sure thatll be finding its way into the s1... seems like its a bit less pissing around than the mtx75....
Old 09-02-2008, 05:22 PM
  #47
Luca
Lukesville
Luca's Avatar
Still alot of messing around to do, what you have to remember is you need to use everything to a st170 set up as the fly and clutch is not the same as any other zetec type.
cant use focus rs clutch nor flywheel...
not many decent clutches that will handle the torque on the market.
Old 10-02-2008, 03:25 AM
  #48
wul young
wul young's Avatar
i run mtx75 with quaife atb,equal length shafts,its been in for about 2000miles now and gets abuse every time its out,never had any problems,car is 262@wheels,done all work myself,cost nothing like 2 grand.my new project will be running 6 speed though as mines tops out at 157mph@6500rpm,thats running 3.8 final drive,6 speed gatrac is good for more than that,and in my opinion is easier to fit,each to there own though.
Old 10-02-2008, 08:23 AM
  #49
Rick
Rick's Avatar
I nearly went fot the 6 speed, but the problem is the ratio's. 6th gear is lower geared than 5th on a std RST. With so much torque in a light car, it really doesn't suit me for road use. MTX with 3.4 diff for me i think.
Old 10-02-2008, 09:33 AM
  #50
sas
should be good!
sas's Avatar
Rick on my 205 50 r 15 tyres the car is geared for 180mph at 8050rpm.
S.
Old 10-02-2008, 11:11 AM
  #51
Rick
Rick's Avatar
8050 rpm - i can't see many revving that hard
Like i said, just not for me as its mainly a road car but for something like yours its pukka. I'll be in touch soon, as i will be requiring your services for my new project
Rick.
A.t.p
23-10-2015 07:54 PM
07-10-2015 12:56 PM
XR4
Ford XR Range
01-10-2015 12:46 PM
Sp3no
27-09-2015 07:23 PM
Quick Reply: Gearbox options - RST
