...my saff spec engine wise
...do you think i will get 400bhp?
...std rebuilt engine no porting std cams grp a head gasket (until she blows) t34 .63 with greys...using a MSD chip for anti lag etc..radtec intercooler,side exit 3inch exhaust
...i am hoping this will get 400bhp on big boost..and in theory with the 3.9-1 diffs and strengthened front diff with i assume std 4x4 gearbox (grp n box) should be pretty ok aslong as launching is kept to a minimum?
I want a fast reliablish car..not going big bhp too much money..plus a rally car should be more about torque
My 3 door has run 403 bhp with a standard head/bottom end, 500 cooler, t34.48 and light blues. Its running less than that now, but I have the graph in the folder, and PJ confirmed this on Saturday morning when I took it for a set up.
So yes, I can't see a problem.
Originally Posted by Bosch_Dealer
....so would a .48 sneak 400bhp...or would a .55 be better???
Originally Posted by Dan
I thought it was physically impossible to run 400hp on a .48 housing?
.48 your lucky to get 350bhp
.55 380 at a stretch
.63 will punch over 400bhp
Thats what i have physically seen
I have never seen the power quoted on a .48 ever and never seen a .55 at a genuine 400bhp
Think he needs is Dyno sorting or stop sniffing
Originally Posted by Jasesapphy
Blues will manage the power but not on a .48, unless im ve4ry much mistaken (which i dont think i am)
I have no reason to disbelive him as to what it ran, and I have the graph. He said that he used to have an engine dyno, and cars ran about 30-40 bhp less on the dyna pack than they did on the engine dyno.
Perhaps I am completely wrong and there's not a hope in hell of 400 on a .48. But again, there's no reason to lie to me - I only had it in for a set up to check fuelling etc.
It is a still very fresh engine - less than 12k now from a FULL rebuild including bore, ground crank, fresh head etc. And when it ran the 403 it would have been about 9k on the new build.
Need someone who REALLY knows their stuff to answer. not saying you don't, but one of the well known and knowledgeable tuners.)
i got round about 420-430 on a standard engine runnig a rs500 T4 (bigger rear housing than a t34 .63) and at 28lbs.
and you think you can get 400+ with a t34 .48, i don't think so.
deffo need a bigger housing and lots of boost.
Depends massively on the rest of the spec, but the figures of 350/380/400 above are a pretty good rule of thumb based on what ive seen TBH
350 is plenty if you have huge gobs of low down torque anyway IMHO for anything but 4th/5th gear, and thats not what a rally car is for.
Are you actually going to use it at a rally though?
Ah maybe a bit ambitious then tbh im not on a horse power quest anyway i have built the engine to be punchy and quick with as little lag as possible to make it more usable on the road thanks all for your insight tho will let you know the figures when i eventually get it on the road!!!
What is a reasonable figure to add to an at the wheels figure to get flywheel power?
(I know it is a %, is a guess at best, blah de blah, but is there a figure that can be added as a rule of thumb?)
15% ish, but TBH its all bollocks, it varies massively and is not easy to measure as the rundown losses arent neccesarily the same as the amount lost under load as the friction between the cogs are different.
for me
Originally Posted by CosKev3
Got 406bhp out of mine with head work,T34.63 live mapped MSD greys with L8 ECU.
Peaking at 35 psi and holding 28psi,turbo lasted 6 months running that boost
KOS KEV : That sounds about right.....but remember you were running a .63 ......... Modified Head.........Grey's...........L8 ECU.......Live Mapped, and a huge 35psi of boost. Assuming it was a good engine, then that was still very good to achive anything over 400bhp.
So a standard engine running a .48 has no chance of getting 400bhp at all. If it took you 35psi of boost, modified head, L8 Ecu and a Live Map.....then a .48 is going to run up to about 360 absolute max.
I remember when Mike R was recomending a set-up to go beyond Stage 3......I ran a T34 .55, Big Intercooler, Greys, Live Mapped on a fresh engine on standard cr, and could still only manage 368BHP....and that was running at 2bar (30psi), and I don't think the turbo would have lasted too long at that boost.
Ive noticed simon keeps appearing, if he had spent as much time on customer service as he has hacking this forum he would be worth a fortune now
"coming back from the dead - like his many relatives who died when he didnt return someone,s parts in time"
