It right?
Old Feb 1, 2008 | 11:44 PM
Paulo P's Avatar
Paulo P
Default It right?
That if you fit a 4x4 number plate panel between the rear lights on a 2 wheel drive that you have to drill holes in the rear panel?
I've got a 1988 2 wheel drive with tinted rears fitted with the number plate panel but it appears that someone has drilled the rear panel to fit the numberplate surround Is that normal & how it should be?
If so it looks like I'll be getting that repaired too So much for swapping the rear lights back
Old Feb 2, 2008 | 12:05 AM
The DIVA's Avatar
The DIVA
Yes.... from the factory they had holes drilled in with plastic inserts and the plinth pushed into them....this has obviously been done by whoever fitted the later back lights
When we fitted the plinth to sticky`s car,we removed the studs and just taped it onto the back panel to make changing back easy...
Old Feb 2, 2008 | 12:19 AM
Munch's Avatar
Munch
Mr. Sparkle!
i do hope you keep that car of yours, its a really nice saph
Old Feb 2, 2008 | 12:27 AM
The DIVA's Avatar
The DIVA
Seconded
Old Feb 2, 2008 | 05:01 AM
cossie04's Avatar
cossie04
Had a look at mine yesterday and mines the same. Not quite sure what i`m going to do at the minute
Old Feb 2, 2008 | 06:57 AM
When I took off the ghastly piece of junk from mine, it was just the two normal holes and very adhesive tape that held it on perfectly.
Old Feb 2, 2008 | 10:40 AM
Paulo P's Avatar
Paulo P
Bugger it looks like I'll have to get those welded up if I change the lights back I thought they were held on differently but didn't check
Thanks guys for the comments
Old Feb 2, 2008 | 11:28 AM
jameswrx's Avatar
jameswrx
I put one on my 2wd saph about 10 years ago and yes I had to drill holes.
Amazing how tastes change because I prefer the original 2wd look now.
Often wonder if either of my saph cossies are on here...
