coopers O ring headgasket
my headgasket is weeping down the block under the exhaust i have been told that i dont have to replace the fire rings and can just replace the actual gasket!has anyone done this just replaced the gasket and left the fire rings?as it is alot cheaper
mechanic28
you sure we are on about the same thing then.
a wire rung block you have yes....
if so,why use an expensive gasket.
no dont think we are i have got a coopers O ring headgasket it the same idea as i wired block but u have sodium filled fire rings that sit around the bore where grooves have been machined out of the block to take them!
Re: gasket
Originally Posted by stickertone
i paid Ł420 two weeks ago for one off ggr... beware of cheaper ones!! be carefull there is a difference between wire wrung and coopers ring gasket.....
i know i got my last one from burtons the rings did not even fit did not realise at that stage it is there own one and not a genuine one like the ones from g.g.r!out of interest how did your rings fit?are u changing it due to it weeping down the block?
deathrider666
28-09-2015 07:12 PM
SMILER258
28-09-2015 10:04 AM
