Sponsored by:
Sponsored by:
WARNING new cosworth oil pumps!!
Old 06-11-2008, 11:27 AM
  #201
Matt Lewis
RS & ST Parts Specialists
Matt Lewis's Avatar
All the 4wd pump are now made in house, no more billet type gone back to cast
Matt
Old 06-11-2008, 11:45 AM
  #202
Azrael
Azrael's Avatar
I have billet one I think, from Mike R, should I be worried?
Old 06-11-2008, 07:53 PM
  #203
Fiecos Dan
Fiecos Dan's Avatar
Originally Posted by andrewg
just had another with blank breaking out
Hi Andy,
is this one of the orginal design's? or the newer Wedge blank?
Did you send it back to Cosworth this time?
Originally Posted by Daxcossie
The pressure relief valve was sticking on my pump causing the oil filter gasket to pop out on cold start-up : (.....
Returned to Cosworth to be repaired, but they ended up sending me a new pump instead.
Hello.
How long ago did you buy it? and when did it fail? 2wd or 4wd?
Old 07-11-2008, 09:31 AM
  #204
andrewg
andrewg's Avatar
think it was welded then machined back, i just re welded it and fitted it back in
Old 07-11-2008, 10:47 AM
  #205
Daxcossie
Daxcossie's Avatar
Originally Posted by Fiecos Dan
Hello.
4WD billet type purchased from PJ Motorsport at the end of last year. Failed after less than 6 months (250 miles).
Ive now got another Billet type unit installed, which Cosworth assured me would be ok..............We will see.
Old 07-11-2008, 04:02 PM
  #206
Azrael
Azrael's Avatar
Mine has done almost 1000km's so far, but iit's running-in milage. We will see.
Old 08-11-2008, 10:59 AM
  #207
Fiecos Dan
Fiecos Dan's Avatar
So same design as your 1st one that failed.
Andy,
could you do everyone a favour, and give Cosworth a call, and tell then your've had 2 failures.
And you might even get 2 new one out of them for your trouble's, thats the least they should do.
The newer type come out may 2008, but Cosworth started to wedge the plug just after Andy started this post.
so your 1 that failed, Most of been the one of the weak 1st batch?
Old 21-11-2008, 09:56 AM
  #208
andrewg
andrewg's Avatar
was just looking at a pump i had on the shelf and you can see the blank has a crack already and also the weld is a bit poris
Old 21-11-2008, 10:14 AM
  #209
Azrael
Azrael's Avatar
I think I will try get a new one then
Current ones are supposed to be OK, right? Or am I getting things wrong?
Old 05-12-2008, 10:52 AM
  #210
Andreas
Andreas's Avatar
Just recieved some of the new design pump.
Old 05-12-2008, 10:57 AM
  #211
JTECH James
Passion for Fords!
JTECH James's Avatar
goodluck!
id use wing nuts on the sump if i were you
Old 17-02-2009, 08:53 PM
  #212
cn-racing
cn-racing's Avatar
here is my pump. it was brand new this summer..
Old 21-11-2010, 12:15 PM
  #213
wes
wes's Avatar
This pump came out of my 1200 mile engine (that had dropped a valve so the engine was doomed anyway ), it's only cracked along the bottom so looks like the wedge design has only half fixed the problem that their first batch had:
Old 21-11-2010, 12:42 PM
  #214
Fiecos Dan
Fiecos Dan's Avatar
When was your pump brought Wes?
Old 21-11-2010, 12:52 PM
  #215
wes
wes's Avatar
8th May 2008, a few days before you got your one looking back at page 5 of this post! Has yours been OK? I had noticed that I was getting a slight tapping noise at idle (sounded like a lifter was going) when the oil was hot a few days before my valve dropped, but I put this down to the oil itself as it went away when it cooled down abit, was going to change the oil to see if it was that but I didn't get a chance to and by what I've found it wouldn't have made any difference anyway.
Old 21-11-2010, 01:18 PM
  #216
paddyrs
paddyrs's Avatar
so is the pumps ok now?
Old 21-11-2010, 01:23 PM
  #217
andy130
andy130's Avatar
yes there cast made now they seam to be holding up ok
Old 21-11-2010, 01:45 PM
  #218
Fiecos Dan
Fiecos Dan's Avatar
The pump is what brought my rebuild to a stop, But since i got the 1st one and heard of issue's i waited for a new design one, but since then i have not got the car back together yet, so my pumps still in the box.
Old 21-11-2010, 02:45 PM
  #219
paddyrs
paddyrs's Avatar
whats the ggr pump like?
Old 21-11-2010, 02:56 PM
  #220
wes
wes's Avatar
I'm going to take this pump to Cosworth and see what they have to say, I may just use a hgh pressure pinto pump now as i have oil squirters anyway. Still a major pain in the arse though!
I think this is the latest cosworth design of the pump i have, not heard anything about them other than they are cast now rather than billet.
Old 22-11-2010, 06:44 PM
  #221
Fiecos Dan
Fiecos Dan's Avatar
Yeah, take it back to Cosworth, Let them see whats happened, As its not on really.
big_Rad
15-09-2017 09:36 AM
Dubs44
21-08-2015 02:42 PM
14-08-2015 07:29 AM
st220kyle
Ford Mondeo Including ST
06-08-2015 09:17 PM
martynhomer01
16
04-08-2015 09:55 PM
Quick Reply: WARNING new cosworth oil pumps!!
